2004 Chevy Avalanche
noblemobile
Posted: September 16, 2004 at 3:06 PM / IP Logged
 For some reason The "service air bag" message will not go away, This started to occur after the factory radio was removed. The is no On Star in the car. We have sent it to Chevy to have the light reset & in 10 min. it happens all over again. The dealer knows nothing (well, with out doing a full Diga. Which they want to charge for), any help would be great.
Noble Mobile Electronics
kgerry
Platinum - Posts: 3,455
Posted: September 16, 2004 at 3:53 PM / IP Logged
did you use the proper GM interface?
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
noblemobile
Posted: September 16, 2004 at 4:01 PM / IP Logged
It is a normal harness, the car has nothing special. All that was added was a radio with a GM harness that fits that model. There are 13 pin\wires that come out of the factory stereo
sparkie
Platinum - Posts: 2,061
Posted: September 16, 2004 at 4:25 PM / IP Logged
I think that you should try re-installing the factory radio and see if the problem goes away. You may have got the wrong GM harness plug. Just because it plugs in, dosen't mean it's the correct one. The radio in the 2004 Avalanche isn't like other GM radios. As kgerry mentioned, there are specific radio replacement modules for your truck. Depending on what options are in your truck dictates which one is necessary. Factory radios are now intregal part of your vehicle's electrical and data bus system. Removing them creates problems.
sparky
kgerry
Posted: September 16, 2004 at 4:35 PM / IP Logged
the radios in the 03 and newer full size GM trucks (CK chassis) use an SPS software system that allow for reprogramming the entire software structure of the radio thru the tech II scan tool via a data upload... these radios are substantially different than similar radios in the 03 ST chassis and passenger cars....
Kevin Gerry
Owner/Installer
Classic Car Audio
since 1979
Thursday, March 12, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
