Hoping to salvage deck and eq
rdlan
Posted: October 09, 2004 at 11:18 PM / IP Logged
A friend recently gave me a Kenwood KGC-4042A eq and a Pioneer DEX-P78 deck. He said they were "fried" and were going to throw them away anyway. I don't know a lot about car audio but thought it would be a shame to let these two pieces of equipment go to waste. I did a little looking around on the web to try to find ways to hook them up to see if they work, but did not have much luck. I am not really concerned about an in depth procedure for installation in a car. I just want to know if I can hook up these things to see if they will even turn on since he said they were "fried", so I can decide whether or not to even bother maybe buying more equipment later. Any advice would be greatly appreciated, sorry if this is a repeat question!
Rushman
Silver - Posts: 380
Posted: October 09, 2004 at 11:48 PM / IP Logged
If you have access to a good car battery (out of the car)you could do whats called bench test the units. You'll need some test leads with alagator clips preferably. Take first the black ground wire from the radio and connect it to the negative post on the battery. Then take the Red and Yellow wires together and connect them to the positive post. This should get you power to turn on the units. If you do have lights and power , then try connecting a speaker to each of the speaker leads on the radio one at a time while a CD is in. (or the radio with just static). Good luck. The EQ should have the same color power wires.
Rushman
Silver - Posts: 380
Posted: October 09, 2004 at 11:50 PM / IP Logged
P.S. I forgot...............check the fuse too
jeffchilcott
Platinum - Posts: 2,483
Posted: October 10, 2004 at 1:09 PM / IP Logged
normally when these items fry, they will still power up just no sound...also on most head untis I see the internal amp fry alot, but the rcs will still be in working condition...
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
Sunday, December 28, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
