How would this sound
Vandals909
Copper - Posts: 88
Posted: October 23, 2004 at 3:02 AM / IP Logged
Again 04 Silverado Extra Cab
2  10" jl w3v2's
1 jl 500/1 amp
1 jl 4/300 amp
1set mb quarts 6.5 pce216
1 pair Eclipse 4x6
1 Pioneer Permeir Deh-p560mp.
How do you think system will sound? Any recommendations, all comments welcome.  I have about 2k-2,200 to spend total. Thanks!
Rushman
Silver - Posts: 380
Posted: October 23, 2004 at 10:13 AM / IP Logged
You have a pretty good set  up of equipment there but it also depends alot on the intaller and who ever tunes it in for ya. If its installed properly , I think it should sound pretty clean and tight. Sometimes less is more.
99 F-one fitty
Pioneer Premier H/U
Alpine EQ
Kicker 1200 amp
4 Kicker comp 10s
6 kicker SS65.2 components
Vandals909
Copper - Posts: 88
Posted: October 23, 2004 at 11:22 AM / IP Logged
They are telling me $2800 installed with a up firing box that goes under the seat.  They also said 200 or 300 more to dynamat the doors. I should be able to find it for cheaper than this right? I'am trying to get away with 2k to 2,200. Any comments are appreciated!
Rushman
Silver - Posts: 380
Posted: October 23, 2004 at 12:02 PM / IP Logged
well if your handy enough to remove the door panels your self and can use a heat gun , You could save about $100 and dynomat the doors yourself. Other than that , $2,800 for the whole thing installed isnt too bad.
99 F-one fitty
Pioneer Premier H/U
Alpine EQ
Kicker 1200 amp
4 Kicker comp 10s
boxmaker85
Silver - Posts: 433
Posted: October 23, 2004 at 3:28 PM / IP Logged
Don't go dynamat.  That stuff is a monopoly.  Go w/ brown bread  (here's a link to a place that sells it http://www.b-quiet.com/brownbread.html  ).  The dynamat stuff is overpriced. But other then that yeah sounds like a really nice system.  Have you concidered installing it yourself?  Not to hard if you have some time and a few tools.
forbidden
Platinum - Posts: 5,354
Posted: October 23, 2004 at 3:34 PM / IP Logged
Brown bread is great stuff. As far as the system goes, I would probably change the rear speakers (as good as they are) to the MB Quart DKE110 (they come with a 4x6" mounting adaptor). And not that I forgot the obligatory why no Eclipse cd player?
kfr01
Gold - Posts: 2,121
Posted: October 23, 2004 at 3:57 PM / IP Logged
http://www.raamaudio.com/ is the best value in sound dampening material I've found.  I probably wouldn't go with more than one subwoofer, you probably don't need it unless you're looking to compete.  Otherwise it looks like a great list of components.
Comment on the quart drivers:  as long as you're spending that kind of money I'd put a 3-way system up front with the midrange and tweeter in the kick panel location.  I have the 216's up front in my car and the biggest upgrade I think I could possibly make to move would be to move the midrange drivers to the kick and buy a dedicated midbass driver set for the door.  - I've been doing some measurements of the 216's because I'm a little annoyed with some peaks in the frequency response I hear when listening to some female jazz vocalists.  After playing with TrueRTA and evaluating each speaker one by one w/ the mic in different locations I've determined that the off-axis response of the quart 216 6.5" driver is causing the problem.  It sounds beautiful when reasonably on axis, but since my drivers are in the door locations I'm listening to some pretty great off-axis angles.  The only way I can fix this is either to 1) buy more sophisiticated eq equiptment (not ideal) or 2) put midrange drivers in this kicks.
Anyway, to sum that up I'd say if I were starting off with a decent budget I would be sure to build some midrange drivers into the kick panels.  - or find midrange drivers with better off-axis response.  The Koda 6 set from http://www.adireaudio.com/ is one set I'd consider.
Also, you won't want to run the 4x6" drivers very loudly and detract from the quality sound of your front stage.  If I were you, I'd probably get the same amp, pick some dedicated 6.5" midbass drivers, run 75w to the midbass drivers, 75w to the 216 components, and run the 4x6" (rear fill) drivers off the head unit power.  Also, I'd attenuate the 4x6" drivers so they are 6-10 db quieter than the fronts (or forget the rear speakers altogether).
Hope my ideas are helpful.
New Project: 2003 Pathfinder
heavilymedicate
Silver - Posts: 328
Posted: October 23, 2004 at 4:45 PM / IP Logged
If you want to save  money do the sound dead'n on the doors yourself.  Drop the 4x6's.  Switch to a 2 channel amp instead of the jl 4/300.  How much are you paying for the deck?  Consider one with only two sets of pre-amps, if your not going with rear full-range speakers.  Other then that?  Install if yourself.
Vandals909
Copper - Posts: 88
Posted: October 24, 2004 at 12:25 AM / IP Logged
Other have suggested getting 12's instead of the 10's.  My questions is would the 12's sound as tight and clean as the 10's? Also Do you know where there is a box that will work for 2 12's? The Sealed Enclosure Range is: 1.00-1.50 cu.ft. (28.3-42.0 liters) and the mounting depth is 6.9". This is the only box that I have found, I dont know if it will work , I havent seen anything bigger.  http://www.subthump.com/ctbultra.htm
Any help?
Rushman
Silver - Posts: 380
Posted: October 24, 2004 at 7:24 AM / IP Logged
Your probly not going to find a prefab box for 2 - 12s that fit underneath the rear seat. You will have to custome build somthing like that in addition to raising the seat a few inches. Like the others said earlier , it would probly be best just to stay with the 2 - 10s or even drop one of them and just go with 1 - 10. You would be suprised how much bass you can get from just one , good , clean subwoofer. Your ears dont know the number of subs you have and cant tell the difference. All they hear is a mono tone of low sub frequencies.
99 F-one fitty
Pioneer Premier H/U
Alpine EQ
Kicker 1200 amp
4 Kicker comp 10s
