alpine cd changer
dazed
Member - Posts: 22
Posted: October 09, 2002 at 3:40 PM / IP Logged
I have a alpine cd changer in the trunk with an amp installed also.  It is one that needs the radio set to a certain frequency to get sound from it.  My problem is that the sound quality is poorer that with the original/factory cd in the dash.  Is it because of the radio tuning and i have to live with it or could it be something else.
dazed
Platinum - Posts: 12,488
Posted: October 10, 2002 at 12:34 AM / IP Logged
Your connections to the FM antenna may be dirty or corroded with debris. How old is the system and what year, make and model  car is this ?
Ohmz
Copper - Posts: 193
Posted: October 10, 2002 at 12:40 PM / IP Logged
Sometimes the RF is not good.. but most of the times the quality does get more poor when you add this type of changer. I would make sure you ground wire is good, connections are clean, and the RF is not placed in a bad spot where there can be interference. You can also try changing the channels.
My Personal Installer Note: Connectors are easy, neat, and professional. But do you know how to crimp properly?
dazed
Member - Posts: 22
Posted: October 30, 2002 at 9:50 AM / IP Logged
thanks guys, I cleaned up the connections and moved it farther away from the speaker.....that might have been interfering with the reception.  It is a '93 Mazda MX6, and the system is about 5 yrs. old.  How do I change the channel on it?
dazed
chasesaccessori
Copper - Posts: 198
Posted: October 30, 2002 at 10:01 AM / IP Logged
some you can not!   Others might be on the changer itself or possibly on a box near the ant. connections.
(owner/installer)
Chase's Accessories
Ridgecrest, CA
in business since 92
Wednesday, April 22, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
