False bottom in trunk
bigboi11
Copper - Posts: 83
Posted: December 14, 2004 at 11:00 PM / IP Logged
I was thinking of puttiing a false bottom in my trunk so that I could put my amps in it.  If I were to leave the amps about two or three inches of space would they be alright in that kind of enviorment or would they need more air.  I would just rather it look like there is nothing in my trunk than for it to be an attention grabber.  I have my two twelves back there but I have the speakers facing the front and the box matches the interior so you can't really tell its there.
stevdart
Platinum - Posts: 5,816
Posted: December 14, 2004 at 11:11 PM / IP Logged
You should work out a push-pull dual fan system for a tight enclosure like that.  You could put in vents on either side with fans attached on the underside;  one pushea air out and the other pulls air in.
wheelerdr
Copper - Posts: 337
They would be ok with minimal play, and it also depends on the amp some amps run cool and some run hot, If your amp runs hot than I would ensure that there is proper ventilation
bigboi11
Copper - Posts: 83
Posted: December 14, 2004 at 11:35 PM / IP Logged
The main amp i am worried about is a kicker kx1200.1 It has never even been warm before but it is alsow 25 degrees outside.  It has a built in fan would that be enough.
