amp/woofer efficiency
dwarren
Posted: January 05, 2005 at 1:25 PM / IP Logged
suppose I have a true 1000 watt amp at 2ohms, and suppose i have two 4 ohm woofers rated at 400 watts rms and about 800 or so peak and they run well enough. Alright my question is if I were to put two woofers to the amp that were more in the range of 800-1000wrms would I gain more spl?
Drewt
Copper - Posts: 183
Posted: January 05, 2005 at 2:40 PM / IP Logged
depends on a bunch of thing, but probally so.  Right now, you have waaaay more power than you need.  Running those subs would let you use more of your amp's power, and hence, probally louder...
go for it
-Drew
jeffchilcott
Platinum - Posts: 2,483
Posted: January 05, 2005 at 5:22 PM / IP Logged
well the subs you have now can use the power.   It is a matter of what they are.. List the make and model of the amps and subs
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
dwarren
Posted: January 05, 2005 at 5:50 PM / IP Logged
mtx 1000d and two 4 ohm 7500 series mtx 12's
stevdart
Platinum - Posts: 5,816
Posted: January 06, 2005 at 12:34 AM / IP Logged
It would be a good matchup.  I doubt you'll ever get the volume to the point of over-excursion.  Be extemely anal about setting up the system:  finding the highest point of clean output on the deck and matching the amp gain to it.  And don't use any type of bass boost on the deck or on the amp (as if you would!).
