Door chimes lost
hoaxs
Copper - Posts: 95
Posted: January 15, 2005 at 10:45 PM / IP Logged
I have a 2004 Cavalier.  I just was given a JVC Kamelon.  My wiring harness has no remote 12 volt, so I had to run a fuse tap the JVC.  I relised that i lost all my chimes.  Can some one explain to me how the OEM headunit work with out the remote 12 volt, and how to get my door chimes back.  I know theres some product out that cost 80 bucks or so.  but is there a way for me to do it buy my self.  Any help would help. thanks
Hurry get me a steel hanger, elec tape, zip ties, a monkey and a snorgle. trust me i've ran wires with less
mobileworks
Copper - Posts: 136
Posted: January 16, 2005 at 4:50 PM / IP Logged
The factory door chime is produced in side the stock radio and transmitted through the drivers door speaker.
The stock radio communicates with the vehicles computer via a databus...the computer will tell the stock radio when to turn on, when to emit the door chime sound and can tell the radio to do other things but these are the most noticable.
The interfaces that go for about 60-80 bucks connect to the databus and have accessory 12 volt outputs for switched power....as well as a built in speaker so that you keep your chime....
The cost of these units is well worth it when you consider that they plug right into the factory harness and allow a very quick and painless installation without the lost of vehicle features....
mladams
Copper - Posts: 57
Posted: January 17, 2005 at 7:13 PM / IP Logged
The other problem you will run into is loss of airbags if you do not use that module. I work at circuit city and sell enough of this stuff to know that without it you can run into major trouble.
Matt Adams
Electrical Engineer Major
York College of PA
Chevy Cavy Rally Sport
Hornshockey
Silver - Posts: 520
Posted: March 15, 2005 at 2:59 AM / IP Logged
I've never seen the airbags be affected without using the GMRC1.  Jus the loss of the chimes and the timed delay after ignition off.  How many have you seen trip an airbag system light?
Life moves pretty fast; if you don't stop and look around once in a while; you could miss it.
Saturday, December 20, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
