could i use this amp with my 12''brahma
alldaz
Member - Posts: 30
Posted: February 10, 2005 at 2:16 AM / IP Logged
http://www.cardomain.com/item/POWA2400DB
I'm planning to get a 12'' brahma, I want to see if I could use this amp or would it fry the sub? I know it isn't a good amp but i've used it for a while and I want to see if I could use it with this driver. What will really happen if I do decide to use this amp, will the sq just not be good or will it just not be loud? Can I have suggestions to a CHEAP amp for this driver that will do the job without frying the sub.
Subwoofer(s): Two(2) 15'' Kole Audio KMX-15's
Amplifier: One(1) Power Acoustik Digital Series 2400A
Headunit: Pioneer 860DEH
Speakers:Factory
Yellow Top Battery
kfr01
Gold - Posts: 2,121
Posted: February 10, 2005 at 3:48 AM / IP Logged
Try it. Just set the gains correctly, don't mess with the bass boost or any crap like that, and don't turn your volume knob past where it was set when the gain was set.
As long as you don't clip the thing like crazy you won't damage it.
Don't run it at 1 ohm to the Brahma. Stick with 4-ohms.
New Project: 2003 Pathfinder
blg748
Copper - Posts: 194
Posted: February 10, 2005 at 7:52 AM / IP Logged
Well just take a look at the brahma white paper or the power handling sheet. For 2.1ft^3 ported box a brahma needs only 500Watts. FOr me my plan is to run it witha good 600Wattrs Wrms when i can fidn a brahma.
Kfr01: you think a Phoneix Gold Tantrum T500.2 will be good if i wire the brahma in series for 4 ohm load? the amp puts out a underrated 500WRms @ 4ohms when bridged. Its more l ike 575WRms.... Or should i go inanse and just buy a Pg Tantrum 1200.1 1450WRms @ 4ohms . I like Phoenix Gold so i tend to stick with it.
alldaz
Member - Posts: 30
Posted: February 10, 2005 at 9:09 AM / IP Logged
Thanks kfr01, can I get any more suggestions from you'll. You're the experts here could i use this amp with my 12''brahma -- posted image.
Speakers:Factory
Yellow Top Battery
thapimpfromchi
Silver - Posts: 616
Posted: February 10, 2005 at 11:49 AM / IP Logged
well how much are you looking to spend on an amp? I'm sure we can give out some pretty nice suggestions that'll fit ur price range.
1990 Honda Civic HB:
Clarion DXZ545MP H.U.
2- 6.5" Power Acoustik interiors
Diamond Audio 600.1 amp
Diamond Audio 15" M6MKII
Pyramid PB881X 4 CH. Amp
pimpincavy
Silver - Posts: 880
That amp should be fine for on brahma. If you end up buying a second one at some point in the future (like you said were going to in your other post) you should also upgrade the amp.
uthinkuknoaudio
Silver - Posts: 760
Posted: February 10, 2005 at 5:15 PM / IP Logged
I don't know what that amp is, but the distortion at .5% @ 4 ohms RMS seems a little dangerous... perhaps something with a little better quality? MTX or Hifonics????
"I don't play games. I play Nakamichi and that for real yo" - Probably some japanese kid said this in the early 80's trying to sell stereo out of his trunk lol.
Alpine Guy
Platinum - Posts: 2,478
Posted: February 10, 2005 at 8:30 PM / IP Logged
I would look into something a little better to actually match that sub since you have the Ferarri of subs,,,you can't just use a cavalier motor, know what im sayin?
You shouldn't go over 1000wrms, the tech at Adire told me im pushing it on the red line if i put a 12" in 1 cubic foot with 1000wrms.
alldaz
Member - Posts: 30
Posted: February 10, 2005 at 9:20 PM / IP Logged
I'll be using a 4ohm load putting 900 watts into it, no more so it should be fine. Since i'm putting around 900 watts in the the 12'' brahma how any cu feet do you think the box should be? Steve K can I have your input on this too?
Speakers:Factory
Yellow Top Battery
alldaz
Member - Posts: 30
Posted: February 10, 2005 at 9:29 PM / IP Logged
Thats the subwoofer enclosure that Adire offers with the sub. The box is prefab but made exactly to fit the sub.
Single 12" sealed1.25 ft3 x 150 lbs
24.00" wide x 15.00" high x 9.00" top depth x 13.00" x bottom depth
Do you think that enclosure is sufficient enough if i'm runnin a 4ohm load on the driver..it will be recieving 900 watts
Speakers:Factory
Yellow Top Battery
Saturday, May 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
