redoing my system - need your expertise
Ocuriel
Copper - Posts: 141
Posted: February 14, 2005 at 6:36 PM / IP Logged
I'm getting a fat check from the irs & planning on replacing my current set up. I planned a few systems & would like your toughts on which is the best for sql. I will list prices too as this has a factor on my decision as well. I'm looking to get a 4 channel amp for highs & mids & a another amp for my subs.
SYSTEM 1:
$639. phoenix gold titanium 1000.2 (1000 rms bridged 4 ohms)
$339. phoenix gold titanium 500.4 (4x75 rms 4 ohms)
15" adire brahma $350.-$450.
------total cost roughly $1300-$1500
SYSTEM 2:
$600-$650 memphis belle 1300 5 channel amp
(4x75 rms @ 4 ohms) (1000 rmsx1 @ 1 ohm)
15" adire brahma $350 -- $450
------totals cost $1,000 - $1,200
SYSTEM 3:
$500 pheonix gold titanium 800.1 (800 rmsx1 @ 2 oms)
$339 phoenix gold titanium 500.4 (4x75 rms @ 4 ohms)
2 10" svc infinity perfects vq - I already own
------total cost of amps is roughly $850.00
SYSTEM 4:
$680 cadence zr9 (2,000 rmsx1 @ 1 ohm)
$525 cadence zrs4 (4x????)matching 4 channel amp
$450-$500 re xxx 15"
-------total cost roughly $1,700 + upgraded wiring & charging system.
this is going into a 01 acura mdx.
I'm also open to any suggestions.
thanks in advance.
pimpincavy
Silver - Posts: 880
Posted: February 15, 2005 at 12:31 AM / IP Logged
I think the second would be the best. You only have to deal with one amp, and it is also the least expensive (besides number 3). Keep in mind that you might need a upgraded charging system for that setup to.
kfr01
Gold - Posts: 2,121
Posted: February 15, 2005 at 1:22 AM / IP Logged
Get a separate Memphis 4-channel for the interiors.  Then I'd buy another Memphis for the sub amp.  I'm not a fan of 5 channel amplifiers for the reason that change is harder down the road if it isn't quite what you want.
Of those three subwoofer options I'd personally go with the single Brahma 15".
Unless you plan to compete in SPL competitions anything above 1000w of subwoofer power is stupid, if you ask me.  The subwoofer is rated at 1600w rms.  The max spl jump from 1000w to 1600w will barely be audible at those kind of volume levels.  Not worth it for the 2000w Cadence, imo.
What are you running for your mids and highs?  This will have a larger impact on final sound quality than anything else.
New Project: 2003 Pathfinder
Francious70
Silver - Posts: 629
Posted: February 15, 2005 at 1:28 AM / IP Logged
I'd say #3. But I'm partial to PG.
Paul
Ocuriel
Copper - Posts: 141
Posted: February 15, 2005 at 10:59 AM / IP Logged
kfr01 - My front's are going to be koda comps 6.1 & clarion comps in the rear.
kfr01
Gold - Posts: 2,121
Posted: February 15, 2005 at 11:43 AM / IP Logged
Okay. What do you currently have for amplification?
Do you have the Kodas in the kicks?
Ocuriel
Copper - Posts: 141
Posted: February 15, 2005 at 12:28 PM / IP Logged
I have clarion components in the front & kicker coaxials in the rear powered by a soundstream van gogh 800.5
(4x50 rms + 1x400 rms @ 2 ohms)
even though this system sounds good, I prefer a little louder & much harder hitting bass.
I read many good things about the kodas, so i'm planning on putting the clarion comps in the rear & putting the koda's in the front doors.
kfr01
Gold - Posts: 2,121
Posted: February 15, 2005 at 4:02 PM / IP Logged
Here's what I'd do:
Put the Kodas components in the kicks. Put another pair of just the Koda 6 midbass drivers in the doors. Use it as three way system. Cross them over around 250hz or so. The power handling of your midrange drivers will be increased substantially. i.e. you'll be able to push them louder.
This way you're actually ADDING something to your system. You weren't adding anything other than a few measly watts to your system in any of the above options. The audible difference between 50w and 75w is about nothing. Since the Kodas are probably less efficient then your clarion components you'd probably be LOSING SPL. You fix this problem and add more overall SPL POTENTIAL AND SQ capability by going with my plan. Bi-amping the midrange and midbass sections of your system will produce significant benefits. See: http://sound.westhost.com/bi-amp.htm
Use a 4-channel amplifier up front then. (i.e. 75x2 to the Koda components and 75x2 to the midbass). Drive the rears off your deck power or leave them out. Either way, they don't matter much.
Then go with the Brahma 15" and 1000w or so.
jeffchilcott
Platinum - Posts: 2,483
Posted: February 15, 2005 at 10:42 PM / IP Logged
I am still taking offers on my whole setup if you wanted to buy used.    but if not.   I am in love with the new RE subs, so I really like the last of the setups
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
Ocuriel
Copper - Posts: 141
Posted: February 17, 2005 at 10:51 AM / IP Logged
What do you have for sale jeff?
Wednesday, March 18, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
