door removel
ksutton
Copper - Posts: 94
Posted: March 08, 2005 at 3:01 PM / IP Logged
does any one know how to remove a door on a 01 buick le sabre.
skoldspuppy
Silver - Posts: 342
Posted: March 08, 2005 at 3:10 PM / IP Logged
With or without explosive charges?  door removel -- posted image.  sorry I couldnt resist I was out shooting a 50 cal this weekend
No really pull off the interior panels just like any other door and disconnect the wiring from the entire door, open the door and you should have 2 hinges 1 at the top of the door and 1 at the bottom, they both should have 4 bolts attaching it to the frame of the car, Id use a floor jack under the door to take off the pressure of the weight of the door
Follow instructions in reverse order to install, if you unsure take it to a repair shop
Later
--Skold
2004 Honda Civic Ex 4Dr
Kenwood DDX-7015/W Nav
4 Fosgate T152C
Hifonics Brutus BX1500D
RE XXX 12 in a 4 Cube Snail Shell
auex
Platinum - Posts: 5,041
Posted: March 08, 2005 at 3:43 PM / IP Logged
Open said door, throw car in reverse, hit the gas, wait till you hit something with the door, and said door will be removed. Note you did say DOOR!
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Alpine Guy
Platinum - Posts: 2,478
Posted: March 08, 2005 at 5:36 PM / IP Logged
haha, , my co installer did that to a 99 CLK 430 benz....
forbidden
Platinum - Posts: 5,354
Posted: March 08, 2005 at 6:43 PM / IP Logged
I think that 50 cal would make short order out of pretty much any door. What on earth were you doing and where on earth would you have access to such high powered weaponry? Oh yeah, about the door..... Open it on a busy downtown street, some idiot on a cell phone will take care of the rest. We don't really get those vehicles here in truck country, if we did I would gladly post some pertinent info for you.
skoldspuppy
Silver - Posts: 342
Posted: March 08, 2005 at 7:27 PM / IP Logged
If you must know a friend of mine who used to be ex cop has a Import/export of firearms all you need is a Type 11 ATF licence "IMPORTER OF DESTRUCTIVE DEVICES, AMMUNITION FOR DESTRUCTIVE DEVICES OR ARMOR PIERCING AMMUNITION" it runs you about $3,000 every 3 years and well worth it
We were just testing a Barrett M107  out on some conceret walls and an old ford pinto out here in the everglades, if your ever in florida let me know we'll go shooting sometime.
Later
--Skold
4 Fosgate T152C
geepherder
Platinum - Posts: 3,668
Posted: March 08, 2005 at 10:08 PM / IP Logged
First, remove the door panel and disconnect the wiring.  Try to pop the molex plugs loose and see if the harnesses can fit through.  To remove the door, you should first undo the door stop.  Open the door, and unbolt the little doodad.  You'll probably have to remove the fender to get to the hinges.
oonikfraleyoo
Gold - Posts: 1,069
Posted: March 08, 2005 at 11:10 PM / IP Logged
My uncle works at the Barrett factory. I have one. In Alabama you need no special licence though I have a class 3 manufacturer's licence. If you drive down here, I'll take care of that door.
Nik
Jeeputer Progress
[|||||||||||-] 90%
Check it out.
Sunday, April 12, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
