how-to truck bed cut through
jt73
Copper - Posts: 81
Posted: March 11, 2005 at 5:04 PM / IP Logged
Any ideas?   I have an 03' f-150 and would like to do a cuthrough for 8 subs or so, but have no idea about enclosure type or technical info.    I am thinking of using Brahma's or memphis mojo's...I am thinking I would like 15's back there, i dont know...I have searched everywhere and cant find info on it or pictures.   The most i have found is to do a 10 x 10 or 10 x 12 cut out and seal it with the accordion boot.
Any info you guys might have to help would be greatly appreciated
thanks
Jason
forbidden
Platinum - Posts: 5,354
Posted: March 11, 2005 at 6:03 PM / IP Logged
One must be very careful when cutting a blow through out in the back wall as it removes basically all of the structural integrity of the vehicle or in a lack of better words, the roof will fold up like an accordian and squeeze your head like a watermelon in a accident. It is best to make as small a blow through as possible (relevant to the subs and box) and reinforce the opening with a new metal structure added and bolted to the key points to maintain structural integrety. Asided from that a basic mdf box and the accordain boot is the way to go. Do not protrude the box through into the cab as the box needs to flex independent of the cab. Instead use upholstered cardboard for this task, it gives the same finished look yet will flex with both the cab and box.
jt73
Copper - Posts: 81
sorry i guess i should have titled this topic:  does anyone know how to do a truck bed cut through....my apologies for misleading you guys
oonikfraleyoo
Gold - Posts: 1,069
Posted: March 11, 2005 at 8:30 PM / IP Logged
Use 1/4" steel around the hole you cut. Put it inside and out. Weld it good. That should fix the butchering to the back wall.
Nik
Jeeputer Progress
[|||||||||||-] 90%
Check it out.
jt73
Copper - Posts: 81
Posted: March 11, 2005 at 11:14 PM / IP Logged
thanks for the info  Forbidden and Nik, I appreciate it.   Still in the planning stages and want to get as much info as possible, good and bad.
J
switch_hitter
Copper - Posts: 151
Posted: March 12, 2005 at 9:00 AM / IP Logged
That is WAY overkill. Dont use anything thicker than 1/8th inch steel.
2 Memphis HPO 12s
1 Memphis 1000D
2 Memphis 8s
1 Memphis MC200
4 Memphis 3way 6 1/2s
1 Memphis MC3004
4 Memphis Tweeters
1 Memphis 3-way electronic crossover
2 Memphis 5 1/4
2 Memphis 4s
jt73
Copper - Posts: 81
Posted: March 12, 2005 at 4:36 PM / IP Logged
thanks for the help guys, i appreciate it...as i get more info and get planning and building i will post pics
Tuesday, December 30, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
