poor sound from aftermarket 96 intrepid
inhissirvice
Posted: March 13, 2005 at 7:34 PM / IP Logged
96 intrepid basic amfm cassette standard
6 speakers, 2 in dash, 2 in doors, 2 in rear deck
installed Jensen cm9521 200 watt
I have been all over the forum and seen a lot of posts that were close but not a "final" fix.
symptom: poor sound quality no base response, no sound at all from door speakers
speaker continuity reads 5000 ohms -- is this for real?
is there an amp in this basic sound system?
I have tried the unit power antenna wire to the blue/white wire -- nothing
any help would be appreciated?
thanks
Jack
Jack 96 white intrepid 3.3
geepherder
Platinum - Posts: 3,668
Posted: March 13, 2005 at 10:00 PM / IP Logged
When you pulled the factory unit, did you have a wire with a female spade connected to the back of the radio?  If so, this is the amp ground.  Connect it directly to ground, and let us know if that solves it.
oonikfraleyoo
Gold - Posts: 1,069
Posted: March 13, 2005 at 11:18 PM / IP Logged
Where did you take that ohm reading from? Right behind the HU? Or at the speakers themselves?
Nik
Jeeputer Progress
[|||||||||||-] 90%
Check it out.
inhissirvice
Posted: March 14, 2005 at 3:05 PM / IP Logged
I TOOK THE READING AT  THE STOCK CONNECTOR COMING FROM THE DASH THAT PLUGS INTO BACK OF HU.
THANKS FOR YOUR HELP
oonikfraleyoo
Gold - Posts: 1,069
Posted: March 14, 2005 at 7:33 PM / IP Logged
I'm thinking that your reading the impedance of the factory amp. Not sure, just a thought.
Nik
Jeeputer Progress
[|||||||||||-] 90%
Check it out.
