Midbass
mini14
Copper - Posts: 120
Posted: March 22, 2005 at 9:51 PM / IP Logged
Hi everyone,
I am a cheap guy, but I still would like pretty good sound. I'm not sure if this would work because I haven't had money to try it. If you had a 2 or 3 way speaker, let's say a 6.5", and detached the tweeters would you be left with a midbass speaker? also, what is the difference between a midbass speaker and a midrange?
Thank you
stevdart
Platinum - Posts: 5,816
Posted: March 22, 2005 at 10:21 PM / IP Logged
You would be left with a 6.5" speaker.  Whether it's defined as midbass or midrange or midhighs depends on how you are using it in your system.  For example, a 4" speaker cannot be a midbass because of the limitations of its size...it won't play frequencies low enough to be called midbass.  However, a 6.5" speaker can be used for either midbass or midhighs (both under the 'midrange' category), depending on what frequencies you're sending to it through the crossover.  But of course you would use the larger speaker cone area for low freqs and the smaller cone area for high freqs.
kfr01
Gold - Posts: 2,121
Posted: March 22, 2005 at 10:28 PM / IP Logged
Buy a real midbass cheap from a brand like Dayton or Peerless at http://www.partsexpress.com/
6.5" is the smallest driver I'd start classifying as a midbass.
New Project: 2003 Pathfinder
crzycreations
Copper - Posts: 52
Posted: March 22, 2005 at 11:03 PM / IP Logged
Relating to midbass, should you enclose the midrange? would that increase the bass response or are all midranges just intended for free-air?   Midbass -- posted image.
-Don't buy it, Build it-
kfr01
Gold - Posts: 2,121
Posted: March 22, 2005 at 11:39 PM / IP Logged
Almost all car midranges are intended to be free air. Enclosing them in boxes that are too small will _HURT_ the bass response.
T.Hill
Copper - Posts: 268
Posted: March 23, 2005 at 2:46 PM / IP Logged
Is there any way by looking at the specs to tell if a 6.5 can be put in a small box and not have the bass take a hit?
Pioneer DEH-P980BT, Zapco DCREF1000.4,Pioneer TS-C520PRS, Adire Extremis, MTX TA91002, TC Sounds TC-3000 15"
kfr01
Gold - Posts: 2,121
Posted: March 23, 2005 at 3:52 PM / IP Logged
The loudspeaker cookbook is at home but I believe, if I remember correctly, that you'll want to look for
High Qts, xmax
Low fs, vas
If you really want to know how the response curve would look then input the speaker's T/S parameters into an enclosure modeling program such as WinISD or others.
Try to keep the resulting qtc of the system below 1, if possible.
The crappy part is that not many speaker manufacturers will list the necessary parameters.
DYohn
Platinum - Posts: 10,741
Posted: March 23, 2005 at 5:41 PM / IP Logged
Good memory, kfr01.  :)
One other thing concerning the idea of using an old coax woofer as a mid-bass: many coaxial speaker system have no crossover for the woofer and run it as a full-range.  So while it may be possible to set up a 6.5" coax woofer to operate in the lower midrange area, be sure to use an external crossover and not try to rely on anything built-in.
Friday, April 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
