Looking for good 10's pwd by 250 g4
zownes
Member - Posts: 14
Posted: March 26, 2005 at 11:26 AM / IP Logged
I have a honda civic 2002 and am looking for some good clean bass,what is a better box ported or regular for some 10's and willing to spend $450 on two or three if possible.I have the orion 250g4
deocder
Copper - Posts: 138
Posted: March 26, 2005 at 11:51 AM / IP Logged
Clean, tight bass? I'd reccommend a sealed box.
Loud, boomy bass? I'd reccommend a ported box.
There are a lot of different woofers out there. Personally I have JL Audio 10W3's. I am very satisfied with these and both get 250 watts rms from my Orion 5002. If i did not have JL already I would probably be most interested in Adires Bhramas but I am not sure of the power requirements off hand. Apparently these woofers are very, very desirable. But then again, it all depends on what YOU like and what YOU want. Keep reading!
WTB: Black Leather Acura GSR seats
zownes
Member - Posts: 14
Posted: March 26, 2005 at 11:56 AM / IP Logged
what is the price range on those Adires Bhramas and is there a big difference in sound from a JLW3 or W6
deocder
Copper - Posts: 138
Posted: March 26, 2005 at 12:14 PM / IP Logged
From what I have heard, the Adire's are rather expensive and not readily available from the manufacturer. There is no price listing on their website either.
As far as a big difference in sound? I would not be able to tell you since I have never heard them. Only heard people talk about them and give them tons of praise.
It's all going to depend on your preferences too. JL's makes a fantastic products, even their older W series. Since I already had these, I have not done too much research into the newer subs. Image Dynamics get a lot of praise as well. Lets wait to hear from some more people.
kfr01
Gold - Posts: 2,121
Posted: March 26, 2005 at 12:22 PM / IP Logged
Decoder is right on with Image Dynamics.
They produce very good sound quality drivers, aren't too expensive, are built for use in very small boxes, and are relatively easy to power.
I don't know anything about your amplifier, zowns. Would you post the specs?
Also, I see little point in buying 3 subs over 2. You must double cone area to increase SPL 3db. As the 3rd sub cannot be a doubling of cone area you gain little.
Use the money saved on the third subs for 2 better quality subs.
New Project: 2003 Pathfinder
zownes
Member - Posts: 14
Posted: March 26, 2005 at 12:23 PM / IP Logged
Thanks for the info
zownes
Member - Posts: 14
Posted: March 26, 2005 at 12:30 PM / IP Logged
HCCA 250G4 POWER OUTPUT 2 x 50 @ 4 Ohm 2 x 100 @ 2 Ohm 2 x 200 @ 1 Ohm 2 x 400 @ .5 Ohm 1 x 200 @ 4 Ohm 1 x 400 @ 2 Ohm 1 x 800 @ 1 Ohm SIGNAL PROCESSING Variable Low-pass 45Hz to 5kHz, variable high-pass with INTELLi Q 10Hz to 10kHz, 10dB of boost with INTELLi Q, remote gain capable, selectable AUX out FUSE SIZE (2) 30 ATC DIMENSIONS 18" x 10.25" x 2.25" (457mm x 260mm x 57mm) .These are the specs i found on the internet and i bought this amp 5 yrs ago and powered three w612's jl audio at one ohm stable.
Drewt
Copper - Posts: 183
Posted: March 26, 2005 at 2:10 PM / IP Logged
Infinity Keppa Perfects are awsome subs, espically for the price you can get them for. Get sounddomain store to do a price match for you, and use froogle to find the best price on them.
The Perfects arn't super loud, but they sound awsome!
And definatly use a ported box....
-Drew
deocder
Copper - Posts: 138
Posted: March 26, 2005 at 11:38 PM / IP Logged
OMG I love that amp........fwap Looking for good 10's pwd by 250 g4 -- posted image.
kfr01
Gold - Posts: 2,121
Posted: March 27, 2005 at 1:31 AM / IP Logged
Wow. Impressive amplifier. Let us know what you decide on the subwoofer.
Saturday, December 20, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
