which setup would be louder?
Ti240
Member - Posts: 27
Posted: March 26, 2005 at 2:24 PM / IP Logged
i am going to be hooking up a temporary system in my car and was wondering which setup to go with. i will be using a viper four channel amp bridged into two channels pushing about 230w rms to each channel. i don't know whether to go with two subs (like an eclipse SW6100 series) or one dvc sub (like the SW7100 series). would the increased surface area of the two sub setup be louder than a single sub that can handle more watts and is a higher quality sub? which would give me better sq?
2005 Nissan Frontier - stock
comming soon...
Eclipse CD8443 deck
Eclipse PA5422 4-channel
Infinity Kappa Perfect 6.1 front
MBquart DKE116 rear
Eclipse SW9122 the 12's
Eclipse DA7232 bass amp
doughboy20
Member - Posts: 30
Posted: March 26, 2005 at 11:33 PM / IP Logged
Thats a good question.  I have heard 1 10" sub be louder that 2 12" subs.  When you want to get down to the basics,  it all depends on the box.  If the box is tuned specificially for that sub, then it will sound great.  But since your setup will be temp., then go with 2 subs.  If 2 heads are better than one,  then 2 subs are better than one.  Im pretty sure that there are others out there that will disagree with me.  And if at all possible, why not go to a audio shop and find out fot your self.
1999 Chevy Lumina
Pioneer Deh-p6400 HU
2- Pioneer TS-W304C
2- Pioneer GM-X972 Amps
2- Pioneer GM-X572 Amps
All Pioneer speakers
4- Lightning audio 1 farad Digital Caps
And All Done By Myself
overworked2
Copper - Posts: 132
Posted: March 27, 2005 at 6:42 AM / IP Logged
Perhaps try going for Sound Quality instead of volume....the difference between two subs and one DVC subs is minimal, 3dB from memory, which is just noticeable volume increase. When you consider no top of that it will running off of a 4 channel amp that is designed to run front and read rear speakers primarly and asa sub amp second. Volume is not going to be great in either case...my suggestions is go for what sounds better, have a listen in store and then decide, I know that listening instore can be deceiving but it can at least give you a general idea of what will be happening.
Check all advice given with a meter
kfr01
Gold - Posts: 2,121
Posted: March 27, 2005 at 6:51 PM / IP Logged
Start at reference efficiency.
A doubling of cone area increases efficiency by 3db.
Then look at amplifier power you'll be seeing given the wiring of the woofers.
A doubling of power adds another 3db sensitivity.
A halving of power reduces sensitivity by 3db.
For boxes in similar enclosures this is an easy way to compare which setup will be louder (given an amount of power under the max of the power handling capability of the least capable system - power handling wise).
New Project: 2003 Pathfinder
bigpun78
Posted: March 28, 2005 at 12:55 AM / IP Logged
If it is a temperary setup and you will be pulling it out later to put it into another vehicle, I would go with the single DVC sub. It is a better quility sub and will probably last you longer. You can always add more subs later(with a different amp of cource).
Ti240
Member - Posts: 27
Posted: March 28, 2005 at 12:17 PM / IP Logged
ya that's a real good point overworked2, volume probably wont be all that great either way. better to go quality over quantity, any recomendations? 12" dvc sub rms about 500w, i was leaning towards the SW7100 series from eclispe
comming soon...
Eclipse CD8443 deck
MBquart DKE116 rear
