'91 nissan maxima stereo wiring
Max2000
Posted: March 27, 2005 at 9:57 PM / IP Logged
I jus purchased a '91 4DR nissan maxima. i was wondering does anybody kno where i can get a diagram with the original wire colors or jus the orignal wiring ... im going to install a kd-ar260 made by jvc since the car was purchased without a radio.. can someone pls help me out..
auex
Platinum - Posts: 5,041
Posted: March 27, 2005 at 10:18 PM / IP Logged
You could try the diagram section of the site? Click here.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Max2000
Posted: March 27, 2005 at 10:34 PM / IP Logged
thanks.. i dont kno y i didnt see that.
Max2000
Posted: March 27, 2005 at 11:26 PM / IP Logged
also if any of u have any other information it would be most appreciated.. thank u
oonikfraleyoo
Gold - Posts: 1,069
Posted: March 27, 2005 at 11:54 PM / IP Logged
What other info do you need?
Nik
Jeeputer Progress
[|||||||||||-] 90%
Check it out.
Chad7n7
Silver - Posts: 408
Posted: March 28, 2005 at 6:06 PM / IP Logged
First of all, by requesting that diagram, it looks that you are about to cut the factory wiring, or it has been cut. If it has already been cut, then carry on.
If you still have the factory harness in tact, then don't cut it, go down to your local stereo shop and get an aftermarket harness to wire up your HU. Easiest solution.
MrSector9
Member - Posts: 43
Posted: March 28, 2005 at 8:30 PM / IP Logged
Check out www.maxima.org on the forums... HUGE amount of information for all gens of maxima..
BJ White
1992 Maxima SE Black on Black :)
