Eclipse SW9122 Info
forbidden
Platinum - Posts: 5,354
Posted: April 01, 2005 at 9:00 PM / IP Logged
I have lost my old Titanium driver info and it is going to be at least a week or more before my subs show up. I need the mounting depth, width etc. if someone has it handy.
Chad7n7
Silver - Posts: 408
Posted: April 01, 2005 at 9:20 PM / IP Logged
Here you go Rob.
forbidden
Posted: April 01, 2005 at 9:37 PM / IP Logged
Close but no banana Chad, unless I missed the info, I did not see the actual physical dimensions of the driver. For the port info, do you know if that was a round port or a slot port?
Chad7n7
Silver - Posts: 408
Posted: April 02, 2005 at 1:21 AM / IP Logged
Rob, the specs are somewhere on here, I had them but lost them, The page I sent wasn't the one I wanted too, but I figured I would send the whole site, as it seems to be a pretty good reference for Eclipse's products. So here you go, hope you can find it!! I kept getting sidetracked and having to start over.
Ravendarat
Platinum - Posts: 2,806
Posted: April 02, 2005 at 7:17 AM / IP Logged
size = damn Big
wieght = damn heavy
hope that helps a little :)
haemphyst
Platinum - Posts: 5,059
Posted: April 02, 2005 at 9:10 AM / IP Logged
I am looking for the manual for mine. As soon as I lay my hands on the thing, I'll post everything you need... Hang tight, bro'...
(...now where did i see that thing???...)
DYohn
Platinum - Posts: 10,741
Posted: April 04, 2005 at 5:25 PM / IP Logged
Hey Rob, don't know if you still need this, but I finally got your answer from a friend of mine:
The cut out hole for the SW9122 is 11" and the flange depth is 13/16." Mounting depth 8 1/16" box size 0.9-1.25 cuft. for a sealed box. Ported is 3.0 cuft. tuned at 35 Hz
haemphyst
Posted: April 04, 2005 at 7:18 PM / IP Logged
DYohn beat me to it, again... I had JUST found my manual for that driver, and those are good numbers. Hadn't forgotten about you! Just took longer than I planned on...
