wiring 6x9 & amp
young rikanz
Posted: April 04, 2005 at 1:59 PM / IP Logged
in my 98 camry, I took out the factory 6x9 and instaled two aftermarket ones that are rated up to 280watts each, I decied that i wanna run an amp to them so i can get louder sound out of them, I wired the amp and it works fine, but the problem is i dont know if i need the RCA plugs or not cause im not getting any sound out of the speakers when i hook them up to the amp, so do I need to run the RCA plugs out of the back of the headunit and if i do what plugs I use the rear or front??
geepherder
Platinum - Posts: 3,668
Posted: April 04, 2005 at 9:12 PM / IP Logged
Yes, you have to send the amp a signal before it amplifies anything.  How is the amp working fine if you get no sound?  If you're powering the rears, use the rear RCA outputs.
overworked2
Copper - Posts: 132
Posted: April 04, 2005 at 9:38 PM / IP Logged
geepherder, I admire your patience!
Check all advice given with a meter
young rikanz
Posted: April 05, 2005 at 7:30 PM / IP Logged
ok thankz geepherder, what i ment by the amp is working fine is, its turning on but no sound, oh yea and i think i had the RCA plugs going into the front plugs for some reason lol, thankz again tho.
