Pioneer KEH-P5000 wiring?
Glorg
Posted: May 30, 2005 at 10:09 AM / IP Logged
I have an old Pioneer KEH-P5000 I want to toss into my truck but I don't have the install manual.  Thus, I dont know what collor wire goes to what speeker on the unit. Can anyone help me out?
samroza
Member - Posts: 43
Posted: May 30, 2005 at 11:18 AM / IP Logged
Glorg
Posted: May 30, 2005 at 12:16 PM / IP Logged
been there, done that, broken links or something. but not much help.
samroza
Member - Posts: 43
Posted: May 30, 2005 at 12:23 PM / IP Logged
Works just fine for me.
Anyhow, standard speaker coloring should be like the below:
Left Front: WHITE/ White Black
Right Front: Grey/Grey black
Left Rear: GREEN/ Green black
Right Rear: PURPLE / Purple Black
I don't know if your model is the same, but it appears that the KEH-P5900 is colored to the standard, and I assume most are.
Sam Roza
Glorg
Posted: May 30, 2005 at 1:11 PM / IP Logged
hum, dont know why I cant connect to that link??? odd
what I have is a
Green, green with black strip, gray, gray with black strip, green with red strip, black with grin strip, black with gray stip, gray with red strip.
samroza
Member - Posts: 43
Posted: May 30, 2005 at 1:14 PM / IP Logged
Try copying the link into your browser.
Sam Roza
samroza
Member - Posts: 43
Posted: May 30, 2005 at 1:17 PM / IP Logged
I can't find a KEH-P5000 on their list of HUs, so I can't help much more than I already have.
Sam Roza
Glorg
Posted: May 30, 2005 at 1:26 PM / IP Logged
Thanks for trying anyway.
I can go to the site, but for some odd reason, my browser wont let me look at a pdf doc. my adobe reader wont work there.
dedlyjedly
Copper - Posts: 94
Posted: May 30, 2005 at 4:06 PM / IP Logged
well, pioneer was the last major manufacturer to adopt the wire color standard we ahve all grown to know and love.
i can't remember whether the black tracers are fronts or rears, but the green sets are the left side and the grey sets are for the right side.
you should just adjust the fader on your deck so that only the front should be playing.  as you are hooking up the wires you can guess and check to confirm proper wiring.
MECP certified, 5yrs experience, you probably otta listen bitch!!
Glorg
Posted: May 31, 2005 at 11:22 AM / IP Logged
Here is what I found. I thought I would share with ya all should this issue come up again in the furure.
Q. What is the wiring for my car stereo, 1999 or older
Pioneer KEH-P5000 wiring? -- posted image.
A. Before 1999 - Low Power Car Stereo KE models only.
GREEN - left front positive
GREEN WITH RED STRIPE - left rear positive
GRAY - right front positive
GRAY WITH RED STRIPE - right rear positive
BLACK - negative for all speakers
RED - switched power
ORANGE - constant power
BLUE - trigger for amp or power antenna
YELLOW = to lighting switch terminal.
Then connect a ground wire from the center post on the back of the radio, to chassis ground.
Before 1999 - High Power Car Stereos DEH & KEH Models only.
GREEN is the left front ( + ).
GREEN/ BLACK is the negative ( - ).
GREEN/ RED is the left rear ( + ).
BLACK/ GREEN is the negative ( - ).
GRAY is the right front ( + ).
GRAY/BLACK is right front negative. ( - ).
GRAY/RED is right Rear Positive ( + ).
BLACK/ GRAYis the right rear negative ( - ).
RED is the Acc lead.
ORANGE is for memory.
BLACK is ground. ( - ).
BLUE is for power Ant.
YELLOW is to lighting switch terminal.
1999+ Models - DEH & DEHP , KEH & KEHP
WHITE = left front speaker positive
WHITE/ BLACK = left front speaker negative
GREEN = left rear speaker positive
GREEN/ BLACK = left rear speaker negative
GREY = right front speaker positive
GREY/BLACK = right front speaker negative
VIOLET = right rear speaker positive
VIOLET/BLACK = right rear speaker negative
YELLOW = to terminal always supplied with power
RED = to terminal controlled by ignition switch
BLACK = chassis ground
BLUE/WHITE = to system control of power amp or power antenna
ORANGE = to lighting switch terminal.
