making subwoofer box?
Blackiewrx
Copper - Posts: 56
Posted: June 02, 2005 at 11:58 AM / IP Logged
if im going to make a ported box for two subs and the specs for one of them is 1.5 cubic ft and a port 8 inches long with a 3 inch round opening, would i just double the airspace and and the size of the opeing on the port and leave the port length the same---> 3 cubic ft and a 6 inch round port 8 inches long? or is their more to it than that?
03 wrx stage 4
sparkie
Platinum - Posts: 2,061
Posted: June 03, 2005 at 8:53 PM / IP Logged
You shouldn't do it that way. You would be better off building one large box with two chambers inside it that each have 1.5 cubic feet of space and a 8 inch long, 3 inch diameter port.
sparky
forbidden
Platinum - Posts: 5,354
Posted: June 03, 2005 at 8:55 PM / IP Logged
One port in each chamber. Do not combine the encosure volume. This of course is also provided that the subs are identical as well.
