pyle
rock1
Copper - Posts: 120
Posted: June 18, 2005 at 12:22 AM / IP Logged
Im getting no power from my pyle plcd46 cd player.
I got it setup with a harness that connects to the car.
The car is a 92 mazda 929.
I got left over wires from the cd player that does not even connect to the harness. I need help setting this up.
shiftmx11
Member - Posts: 27
Posted: June 18, 2005 at 3:18 AM / IP Logged
what colors if its blue or blue white dont worry about if it is your black wire then just sreaw the HU in to the dash becuase the metal brackes that hold the radio in the dash acts as your ground.
if that dont work then its your PYLE raido PS stay away from pyle next time
shiftmx11
Member - Posts: 27
Posted: June 18, 2005 at 3:21 AM / IP Logged
hold on i might be wrong sorry, thinking of a diffent car it might be the same tho
Chad7n7
Silver - Posts: 408
Posted: June 18, 2005 at 9:59 AM / IP Logged
If you have used an aftermarket harness, and have made all of your connections properly, then try checking your fuses. If they are all good, then take a DMM, and check your wires at the HU to single out your problem, using the ground wire from the HU, if you have constant +12V ( yellow ) and switched +12V ( red ). then your unit is probably no good.
rock1
Copper - Posts: 120
Posted: June 18, 2005 at 10:48 AM / IP Logged
I connected the harness but I got some wires from the cd player that goes not connect to the harness. I got the backlighting wire and some other wire where does that go. the main power connects to the harness and the black goes to ground.
haemphyst
Platinum - Posts: 5,059
Posted: June 18, 2005 at 10:52 AM / IP Logged
hehe he said "pyle"..
rock1
Copper - Posts: 120
Posted: June 18, 2005 at 10:53 AM / IP Logged
whats wrong with pyle?
haemphyst
Posted: June 18, 2005 at 11:07 AM / IP Logged
Did I say there was anything WRONG with Pyle? Sounds like a persecution complex. Do you know of something wrong with Pyle that I'm not aware of? Calm down, man pyle -- posted image. Just making a joke...
(Pyle sounds like pile - as in pile of shhh - just a joke. Ya know Beavis and butthead, from MTV?)
Gawd, I hate having to explain a punchline pyle -- posted image.
DYohn
Platinum - Posts: 10,741
Posted: June 18, 2005 at 11:22 AM / IP Logged
Especially when it's appropriate!
rock1
Copper - Posts: 120
Posted: June 18, 2005 at 11:24 AM / IP Logged
Im just asking. I dont like there customer service. its not like other brand names.
