2000 toyota sienna color codes for audio
Welcome Guest :)
imspidey
Member -
Posted: July 04, 2005 at 12:38 AM / IP Logged
i dont have the standard setup for this vehicle so the aftermarket adapter plugs dont fit...i have an upgraded system through toyota that essentially has a built in amp and the plugs are different. this website as well as others show wire colors that are only accurate for the rear speakers.
imspidey
Platinum -
Posted: July 05, 2005 at 9:25 AM / IP Logged
| Wire Function | Color | Note | Fuse # | Size | Location | | | +12V DC Battery(Constant) | Blue / YELLOW | | Radio 1 | 20 Amp | Junction block on left side of engine compartment. | | | Switched Accessory | Gray | | Radio 2 | 7.5 Amp | Junction block behind dash, on left side of steering column. | | | Ground | Brown | | | | Power Antenna | BLACK/ red | | | | Remote Turn On(output) | Violet | | | | Illumination | Green & WHITE/ green | | | | Mute | Blue | | | | Left Front + | White | Line level output | | | Right Front + | Red | Line level output | | | Left Rear + | Yellow | Line level output | | | Right Rear + | Brown | Line level output | |
AMPLIFIER OUTPUTS |
| Wire Function | Color | Note | Fuse # | Size | Location | | | 12V DC Battery | Blue / YELLOW | | Radio 1 | 20 Amp | Junction block on left side of engine compartment | | | Remote Turn On (input) | Violet | Also gray for accessory switch, thru radio 2 fuse as above. | | | Left Front Mid + | Pink | | | | Left Front Mid - | Violet | | | | Left Front Tweeter + | Blue / YELLOW | | | | Left Front Tweeter - | Blue/black | | | | Right Front Mid + | Light green | | | | Right Front Mid - | Blue | | | | Right Front Tweeter + | Blue/white | | | | Right Front Tweeter - | Blue/red | | | | Left Rear Mid + | Black | | | | Left Rear Mid - | Yellow | | | | Right Rear Mid + | Red | | | | Right Rear Mid - | White |
imspidey
Member -
Posted: July 08, 2005 at 11:14 PM / IP Logged
thanks for the additional info however the colors still dont match.....am i going to be able to wire from the current plug wires or am i going to have to go to the harness? also is there a way to test where the wires go to figure them out that way? thanks
imspidey
imspidey
Platinum -
Posted: July 09, 2005 at 12:31 AM / IP Logged
Most of the time the radio plug fits in after the amplifier. Have you checked to see if the plug fits the output on the amplifer ?
Thursday, March 5, 2026
• Copyright © 1999-2026 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
