Amp goes into protect?
jaymes
Copper - Posts: 47
Posted: July 05, 2005 at 8:56 AM / IP Logged
My subwoofer amp goes into protect mode every so often when the bass hits deep or the volume is up a little bit. The level is only on about half way and it is not even bumping very hard, but still cuts out. WHat could the problem be? Also, i have a level knob, a lpf knob, and a hpf knob. How should these be set?
Platinum - Posts: 12,488
Posted: July 05, 2005 at 9:15 AM / IP Logged
What is your input sensitivity for your RCA's on the amplifier in comparison to your head unit's RCA voltage ? Some amps can not handle the high output's from HU's.
jaymes
Copper - Posts: 47
Posted: July 05, 2005 at 11:25 AM / IP Logged
i have a panasonic CQ-DFX701U  headunit and a Lanzar Vibe 258 amp. Would the voltage problem only occur at high volumes?
Optik
Copper - Posts: 53
Posted: July 05, 2005 at 11:32 AM / IP Logged
Do you have your gain properly set to the head unit?
nathan_454
Member - Posts: 16
Posted: July 05, 2005 at 11:34 AM / IP Logged
yes as you turn up your volume it raises the output voltage to that amp, or so i understand... this could be your problem... what size wire are you running for power? I personally dont have any experience with lanzar amps, but i dont think they are too great... what ohm are your speakers wires to?
MY System, Pioneer Owns...Thanx Gabe
HU: DEH-P770MP
Fronts: TS-C160R
Rears :TS-A6995
Subs: 2x TS-W106C
Sub Amp: GM-7150M
4 CH: GM-6150F
jaymes
Copper - Posts: 47
Posted: July 05, 2005 at 12:06 PM / IP Logged
how do i set my gain properly to my headunit. I am running 0 awg wire to the amps(overkill).
Optik
Copper - Posts: 53
Posted: July 05, 2005 at 1:02 PM / IP Logged
www.bcae1.com look to the left and select #63 "setting gains"
Thursday, April 23, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
