tri tune box
pavan
Posted: July 07, 2005 at 1:06 AM / IP Logged
hello i just bought a new car 1996 bmw 325i full reiger kit i wanted to make a new box since my old stereo got sold with my old car. i am wanting to build a tri tune box but kinda confused i try to stay away from box building cause of the complexity. i have a 12" alpine type r dual vocie coil 4 ohm . and am powering it with a alpine mrv 1005 amplifier. if anybody has built this box before can u plz post me a rough outline of the dimesions. i know the tri tune boxes sound hectic. or if anybody has a site in whick would help me to build a box  sealed box volume should be 0.8 and 1.0 cubic feet. if anyone can help i would appericate it thanks
Bigsingh
Copper - Posts: 204
Posted: July 07, 2005 at 3:58 AM / IP Logged
ok , well if you are looking for an SPL application there is no real point in building a  ported box because this sub is more for SQ applications. You will not get SPL results if thats what you are looking for.
6* Rockford T2's
6* POWER AMPs
BLACK CORRADO
BAANNGGIINN
haemphyst
Platinum - Posts: 5,059
Posted: July 07, 2005 at 9:04 AM / IP Logged
What is a "tri tune box"? Are you referring to a bandpass enclosure, where the woofer is buried inside the box, and vented to the outside? Never having even HEARD of a "tri tune box", I can't help you, and I bet most anybody else here wouldn't be able to, either...
stang351w
Silver - Posts: 350
Posted: July 07, 2005 at 9:32 AM / IP Logged
a "tri  tuned" box  if i remember right is a vented box  made to spec for the sub then it has an addition on the side that i beleive is about half the size of the part with the sub..then you put a port to connect the two box's and a port comming out of each box as well... but the whole time the sub is still seen outside the box
Tri County KustomZ
certified installer
oonikfraleyoo
Gold - Posts: 1,069
Posted: July 07, 2005 at 9:49 AM / IP Logged
This is not true. The Type R's work very well in ported boxes, and get quite loud. Not sure about a tri tune box??
Nik
Jeeputer Progress
[|||||||||||-] 90%
Check it out.
gus1
Gold - Posts: 1,013
Posted: July 07, 2005 at 2:23 PM / IP Logged
Tri Tuned box= BOSE Acoustimass sub.....
Be very very prepared to do some very serious math, and a pretty big box.... the Bose box has I believe 2 5.25" woofers in it, and is fairly big.
Do a simple ported or sealed.... your brain will thank you later.
Gus
pavan
Posted: July 08, 2005 at 6:07 PM / IP Logged
yah i went down to my local stereo store n he has some kicking so im just gonna buy one or my buddy has on with a 12" alpine type r im just gonna steal the meassurement those boxes sound nuts theyre loud as hell plus u get nice deep bass, hits teh lows without bottoming out
Friday, April 24, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
