3 amps and remote turn on?
xikecongtu
Member - Posts: 10
Posted: August 03, 2005 at 1:47 PM / IP Logged
HI:
I have : 1 head unit, 1 EQ, 2 components speakers (front/rear), 3 amps (1100Watt), 3 caps.
My question is, can i stack 3 amps on top of each other (pro: no wires are cross over and suspends noises, cons: will produce alot of heat)?
Do i need a "relay" for remote turn on "blue wire" for 3 amps, since it the reciever produce limited of current?
thanks,
concu
Francious70
Silver - Posts: 629
Posted: August 03, 2005 at 2:25 PM / IP Logged
Yes, you will. Don't forget, you'll have to turn the EQ on too.
And yes, you can stack three amps together, just make sure there is some space between them with air moving thru there .
Paul
xikecongtu
Member - Posts: 10
Posted: August 03, 2005 at 2:31 PM / IP Logged
Paul
thanks,  since i never install w/ the relay before,,,can you give a little description...how to coneection them...
concu
geepherder
Platinum - Posts: 3,668
Posted: August 03, 2005 at 3:04 PM / IP Logged
https://www.the12volt.com/relays/page5.asp#rtol
TruckSystem
Copper - Posts: 185
Posted: August 03, 2005 at 3:33 PM / IP Logged
I have a short wire jumping from one amp to my other amp with no relay or anything else, has been like that for almost a year now with no problems.
2003 Chevrolet Silverado Standard Cab ~ Alpine CDA-9851
Diamond Audio D3600.1 ~ 2x Diamond Audio TM310D4
Diamond Audio D3400.4 ~ Diamond Audio Hex S600s
AstroStart RS5204 Remote Start/Alarm
geepherder
Posted: August 03, 2005 at 3:57 PM / IP Logged
Yes, but if you use more than two components, it's always recommended to use a relay so you don't fry the transistor for the remote turn on inside your head unit.
xikecongtu
Member - Posts: 10
Posted: August 04, 2005 at 11:24 AM / IP Logged
Paul
how far apart do i need to separate them.....and is there material to \put in betwween in which it resistence the  heat....
concu
xikecongtu
Member - Posts: 10
Posted: August 04, 2005 at 12:12 PM / IP Logged
how many relay do i need for 3 amps 1 head 1 eq
concu
Francious70
Silver - Posts: 629
Posted: August 04, 2005 at 2:03 PM / IP Logged
You will only need 1 relay if you get the 30 amp version from radioshack.
And I would put at least 3" of space between each amp, to put computer fan in your amp rack to help circulate the air.
Paul
Saturday, March 7, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
