Posted: August 05, 2005 at 9:45 PM / IP Logged
Posted: August 05, 2005 at 10:46 PM / IP Logged
Posted: August 06, 2005 at 2:19 AM / IP Logged
Posted: August 06, 2005 at 9:24 AM / IP Logged
Posted: August 06, 2005 at 9:43 AM / IP Logged
Posted: August 06, 2005 at 10:30 AM / IP Logged
Posted: August 06, 2005 at 5:03 PM / IP Logged
Posted: August 06, 2005 at 6:22 PM / IP Logged
Posted: August 06, 2005 at 11:05 PM / IP Logged
Thursday, November 27, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
2200 watts (OUT) times 1.33 = 2926 watts (IN) divided by 12 volts (nominal, NicP) equals 243.3 amps.
Does 243.3 amps "fit" into a 170 amp alternator? No. are you going to be running 2200 watts ALL THE TIME? NO, and I GUARANTEE that... I have close to 6kW in my trunk, and I am using a 165A alternator... not a single problem. BUT, to answer your question in an absolute fashion, no, it will not be big enough. sedate told you there are mitigating circumstances to this answer, and I have told you that I am running FAR more than one woud think would be possible on my alternator...
(Also keep in mind this 170A is probably a clod rating - you need to derate by a MINIMUM of 10 to 15% for hot output...)
