sub wiring ohm
june
Posted: September 23, 2005 at 10:30 AM / IP Logged
ok is there any possible way that i can wire 2 dual voice coil 4 ohm speaker to see 4ohm i have one way but im not sure if that the right way i wired each speaker to see 2 ohm which is parallel then i will take both and put it in series is that safe for the mono amp which is 4 ohm  right??????????????
jstruckman
Copper - Posts: 465
Posted: September 23, 2005 at 10:35 AM / IP Logged
You will usually want to wire the voice coils in series so each sub is 8 ohms. then parallel the subs to bring it to a 4 ohm load.
Jazzy
haemphyst
Platinum - Posts: 5,059
Posted: September 23, 2005 at 10:40 AM / IP Logged
You are correct as well... Leave it that way.
Sunday, December 21, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
