aftermarket amp to factory radio
ezko84
Posted: November 25, 2005 at 8:47 PM / IP Logged
after all day of searching online I still can not figure out the wiring schematics of my stereo system.
I am installing an after market amplifier from my factory radio to power a sub.  the only problem is that there are no RCA output jacks on the radio.  So I purchased a HI-LO line converter that has 1 pair stereo outs, 2 grey, and 2 white wires that need to be spliced and installed from the factory radio.  I would like to know where these 4 wires get connected to.
I also need to wire the rem from the amp.  I am not exactly sure where it gets wired to.
I have a 06 Toyota tundra
Toyota factory cd tape deck (fujitsu-ten)
godblessdremil
Silver - Posts: 273
Posted: November 25, 2005 at 10:30 PM / IP Logged
For remote wire(if you are getting it from the fuse box) i would use an unimportant slot that gets only accessory power, because sometimes things burn out.
Friday, February 20, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
