amp wiring
dzelaya18
Copper - Posts: 49
Posted: December 05, 2005 at 11:29 AM / IP Logged
Okay, my 2 channel Audiobahn amp's manual says that it produces 400watts rms (200 per each channel) at 4 ohms. The subs are Cerwin Vega V-Max 12's, SVC 4 ohm. Right now, I have each sub wired to its own channel. My question is, how do I wire the subs to the amp so that it is bridged? because the amp will priduce 560watts rms bridged.
DYohn
Moderator - Posts: 10,741
Posted: December 05, 2005 at 11:41 AM / IP Logged
What's the amplifier model number?
supradude
Silver - Posts: 915
Posted: December 05, 2005 at 11:43 AM / IP Logged
Look at the amp, where you have the speaker wires connected to it, if you don't have the manual for the amp. It should tell you which way to connect the wires. Both negative from the subs go to one channel on the amp, and both positive from the subs go to the other channel, usually.
'85 Toy
dzelaya18
Copper - Posts: 49
Posted: December 05, 2005 at 11:52 AM / IP Logged
Its the A2801T.
On the amp, on the speaker terminals, its says "bridged" and has lines drawn to the two outside posts. Would that mean that I would wire the two inner wires to the amp and then the two outer wires to each other?
DYohn
Posted: December 05, 2005 at 12:15 PM / IP Logged
Your amp is marked to use the outer most speaker connection points when bridging (see page 20 of your owner's manual.)  It is rated for no less than 4-ohms when bridged (see page 5 of your owner's manual.)
You will not gain any power increase with your speakers since you'd have to wire them for 8-ohms to bridge, and this will result in the same net effect you have now.
DYohn
Posted: December 05, 2005 at 12:16 PM / IP Logged
No, it means you use the two outer connections for the speaker and leave the inner ones empty.  See page 20 of your owner's manual.
dzelaya18
Copper - Posts: 49
Posted: December 05, 2005 at 12:29 PM / IP Logged
OK, thanks.,
Thursday, December 4, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
