How to calculate this box
dabper
Member - Posts: 7
Posted: January 11, 2006 at 3:26 AM / IP Logged
How to calculate this box -- posted image.
hello evey body
memphis11223344
Member - Posts: 34
Posted: January 11, 2006 at 9:45 AM / IP Logged
that box is shhh, its the same box as the dual set up. i wouldnt even bother putting that in.
6 memphis PR 15's sealed enclosure. indash mobile video system. alphasonik HC800PMA 3000 rms
MECP first class installer
kirktcashalini
Silver - Posts: 492
Posted: January 11, 2006 at 2:51 PM / IP Logged
a big 10-4. and what do you need to calculate about a pre-fab anyway? if it plays it plays, not much you can do to edit the sound.
youngone
Silver - Posts: 269
Posted: January 11, 2006 at 2:55 PM / IP Logged
make your own with slot ports. will sound a lot better. + you gain knowledge in the process.
Want to know some good equipment- JL,Adire Audio,Mcintosh,Brax,Helix,Eclipse,JBL,RE,Dimoand Audio,Zapco, pritty much anything DYhon,Forbidden recommend
On the12volt you give some info and you get in
dabper
Member - Posts: 7
Posted: January 12, 2006 at 2:12 PM / IP Logged
hello evey body
DYohn
Platinum - Posts: 10,741
Posted: January 12, 2006 at 2:20 PM / IP Logged
And your question is...?
Both enclosures above are 4th order bandpass systems.  They would perform differently due to driver displacement issues unless the chamber volumes were adjusted accordingly.
dabper
Member - Posts: 7
Posted: January 12, 2006 at 2:28 PM / IP Logged
what is program for calculate it?
hello evey body
DYohn
Posted: January 12, 2006 at 3:18 PM / IP Logged
dabper
Member - Posts: 7
Posted: January 21, 2006 at 8:37 AM / IP Logged
(Top/Left in picture)
hello evey body
bellsracer
Silver - Posts: 703
Posted: January 22, 2006 at 2:13 AM / IP Logged
considering the space taken up, the size of the woofers, and the setup they have going, I'm betting that it is one of two types:
1) (the most likely one) It is a basic type two (or second order) sealed box with the woofer facing out to shrink the box down some more. -or-
2) It is a type four (forth order - another sealed box) Passive Radiator setup with the cone underneath it acting as a tone diaphragm to give it a smoother bass tone and to shrink the box a lot. This setup allows a really small box to be used for this kind of design as well.
That is... unless those darker blue circles are ports... In which case it is a basic Bass Reflex ported box with a clever design for finding enough space for it. They don't look like ports to me though... they sit on the surface of the box(s) and look pretty solid.
Tuesday, March 31, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
