Hiss and little volume control
italianlj
Posted: January 29, 2006 at 1:46 PM / IP Logged
I have just put a dvd/cd/radio in my 2000 toyota celica. It has a factory installed amp. I now have engine noise when the radio is playing and a loud hiss while the dvd is playing and the volume contol goes from loud to real loud. No real control. Can anyone help??
Larry
DYohn
Moderator - Posts: 10,741
Posted: January 29, 2006 at 2:36 PM / IP Logged
Did you remember to remove or bypass the factory amp?
geepherder
Platinum - Posts: 3,668
Posted: January 29, 2006 at 2:51 PM / IP Logged
The problem you've described is cause by running too strong a signal (speaker level) into the factory amp.  You can use an integration harness (check your other topic), or rewire (bypass) as suggested above.
Thursday, November 6, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
