MTX Thunder 102?
kirktcashalini
Silver - Posts: 492
Posted: February 16, 2006 at 9:36 PM / IP Logged
Hey, I recently got a half oldish still good condition MTX Thunder 102. I am going to run it for a single 10" sub. It was used (duh), and Doesnt have a manual. I could not find a pdf manual online all i could find was
http://www.mtxaudio.com/caraudio/archive/thunder102.cfm
I am wondering about wiring bridged. It probably says right on the damn amp, but I am impatient, and am expecting it in a couple days ebay baby. And Am wondering. I know 4 ohms is the lowest load it will do bridged. But is it L+ R-    or     R+ L-
It is a very budget build, and got the amp practically free, but said it was in good working and visual condition, so I wil give it a try.   Also, is there a difference, if I were to use LOC at the back speakers in the trunk, Or should I use the Speaker Level Inputs (I heard those suck). If It were my car It would be done at head unit, But This is cheap and fast, just to get a little more bass. Thanks for responces.
stevdart
Platinum - Posts: 5,816
Posted: February 16, 2006 at 9:55 PM / IP Logged
It will say right on the damn amp :-)  It is spec'd as bridgeable.  If it's all worn off and you can't see it when you get the amp it will be the outermost terminals.  At least, that would be by rum-induced guess.  For the LOC, consider this:  does the deck have a fader?  And would you normally like to fade the rears a little lower than the fronts?  If so, don't connect the LOC to the back rears because the signal will fade to the sub...attach to the fronts.  Using the built-in is a shot...the first symptom of a problem go get a quality LOC and save yourself the time trying to troubleshoot.  Symptoms can be far-ranging and don't necessarily point at the high level input as the culprit.
