4 channel amp for 2 subs
smokinsmitty
Copper - Posts: 75
Posted: March 08, 2006 at 6:07 PM / IP Logged
Ok my buddy has a 6004T audiobahn amp, well is it ok to only use 2 subs on it! so only 2 channels. will they get 300rmsx2 or only 150 rmsx4? thanks
1 15" Memphis Mojo,
Memphis 16-mc1000D amp,
Audiopipe 4gauge mp kit, Pioneer DEH4700MP head unit.
2002 Yamaha 660R Raptor
Yamaha FZR600 crotch rocket
Sea Doo XP800
Sea Doo Spi
geepherder
Platinum - Posts: 3,668
Posted: March 08, 2006 at 9:04 PM / IP Logged
If you're connecting two subs, as long as you don't go below the recommended ohm levels (2 ohms stereo or 4 ohms bridged, for example), you can bridge two channels of the amp to each sub.
willdkartunes
Copper - Posts: 250
Posted: March 08, 2006 at 9:36 PM / IP Logged
It shouldn't be a problem hooking the 4-channel to those subs. What kind of subwoofers are you hooking it up to?
smokinsmitty
Copper - Posts: 75
Posted: March 09, 2006 at 5:22 AM / IP Logged
2 12" memphis m1 dvc. How would i bridge the 2 channels to run 1 sub! explain this to me
1 15" Memphis Mojo,
Sea Doo XP800
Sea Doo Spi
geepherder
Posted: March 09, 2006 at 7:56 PM / IP Logged
Your original post asked about using 2 subs.  If you want to use a 4 channel to run a sub, I suggest amping the front speakers, then bridging the rear channels to run the sub.  At least until your buddy gets some more gear.
Sunday, November 9, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
