96 Chryslet Cirius, no bass
jwagg
Member - Posts: 19
Posted: March 10, 2006 at 3:53 PM / IP Logged
I just wired in a headunit, and there is absolutely no bass to the front and rear speakers. I didnt wire them in phase, or negative to positive, whats the problem? Any suggestions?
Platinum - Posts: 12,488
Posted: March 10, 2006 at 11:18 PM / IP Logged
Did you use a wiring harness ?
jwagg
Member - Posts: 19
Posted: March 11, 2006 at 10:53 PM / IP Logged
yes, im using a harness. I have heard of sometimes having a single ground for the speakers instead of two......True?
xscash
Copper - Posts: 317
Posted: March 11, 2006 at 11:07 PM / IP Logged
that is called a floating ground....this is not the case...
LF Speaker (+) LIGHT GREEN/ GREEN
96 Chryslet Cirius, no bass -- posted image.LF Speaker (-) LIGHT GREEN/ VIOLET
96 Chryslet Cirius, no bass -- posted image.RF Speaker (+) LIGHT BLUE/GREEN
96 Chryslet Cirius, no bass -- posted image.RF Speaker (-) LIGHT BLUE/VIOLET
96 Chryslet Cirius, no bass -- posted image.LR Speaker (+) BROWN / YELLOW
96 Chryslet Cirius, no bass -- posted image.LR Speaker (-) BLUE/LIGHT BLUE
96 Chryslet Cirius, no bass -- posted image.RR Speaker (+) DARK BLUE/WHITE
96 Chryslet Cirius, no bass -- posted image.RR Speaker (-) DARK BLUE/ORANGE
if you reverse 1 speaker in the front they will be out of phase and cause a no bass issue. check the wires to make sure phase is correct.
jwagg
Member - Posts: 19
Posted: March 11, 2006 at 11:18 PM / IP Logged
right, i forgot the terminology, thanks, i read this before when i searched, i guess ill check again and make sure that everything is wired right, does the / between the colors mean that it could be either color? or is that what to connect it to?
Hornshockey
Silver - Posts: 520
Posted: March 11, 2006 at 11:51 PM / IP Logged
does the bass increase when you fade left to right? how about front to back?
Life moves pretty fast; if you don't stop and look around once in a while; you could miss it.
jwagg
Member - Posts: 19
Posted: March 12, 2006 at 1:34 PM / IP Logged
No, no bass at all.......0. On the diagram, for example, it says RR Speaker (-) Dark Blue/Orange
Does that mean connect the dark blue to the orance wire?
Hornshockey
Silver - Posts: 520
Posted: March 12, 2006 at 2:28 PM / IP Logged
no, that means the negative wire for the right rear speaker is dark blue with an orange stripe. That's the standard for listing wire colors: "wire color/stripe color"
jwagg
Member - Posts: 19
Posted: March 12, 2006 at 5:25 PM / IP Logged
okay, so i should connect it coresponding to the diagram then the harness, i just matched up the colors
geepherder
Platinum - Posts: 3,668
Posted: March 12, 2006 at 7:19 PM / IP Logged
It sounds like you missed the point.  The harness Jeff referred to was not the harness that plugs into the new stereo, but the one that plugs into your factory radio harness.  You can pick one of these up for cheap enough at several places (even Wal-Mart and AutoZone).  Then you just go color to color, and plug it into your factory radio harness when you're done.
