problem with my new amp
dungslung
Member - Posts: 15
Posted: March 15, 2006 at 10:02 PM / IP Logged
I just bought a rockford fosgate p5002 and took out my old amp and hooked up the new one... im using 4 gauge ground and power wire, the same ones i had hooked up to my old amp but the new amp never turns on... i didn't change a thing with the wires and i checked the fuses and everything, they are all good. i don't know why it won't turn on.
dungslung
Member - Posts: 15
Posted: March 15, 2006 at 10:19 PM / IP Logged
would it be because i have the subs wire wrong? how would be the best way to wire the p5002 to my 2 cvr12 12" kickers?
kfr01
Gold - Posts: 2,121
Posted: March 16, 2006 at 12:14 AM / IP Logged
This might be a stupid question, but is your turn-on lead working?
Check your connections again. Make sure something didn't pull loose when you installed the new amplifier.
Do you get -any- activity from the amplifier? A light flicker?
New Project: 2003 Pathfinder
dungslung
Member - Posts: 15
Posted: March 16, 2006 at 10:12 PM / IP Logged
never mind, all good... was a bad fuse, it isn't blown but it just wouldn't work, i switched that and it's good now.
Monday, April 6, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
