03 Hummer H2 PAC Onstar Bypass
digitalas
Member - Posts: 9
Posted: March 29, 2006 at 12:11 PM / IP Logged
Hey guys,
We installed this onstar bypass and the radio will not faid from front to rear. Is this the bypass or is something wired wrong
DigitalAS
digitalas
Member - Posts: 9
Posted: March 29, 2006 at 2:48 PM / IP Logged
guys any word on this issue
DigitalAS
jstruckman
Copper - Posts: 465
Posted: March 29, 2006 at 3:31 PM / IP Logged
First off, it is not a OnStar bypass, it is an OnStar retention interface. The factory radio sends two channels of audio into the amp. The fading was done over the Class II bus. So if you pull the factory radio, then you cannot fade.
doibuy
Copper - Posts: 177
Posted: March 29, 2006 at 5:22 PM / IP Logged
jstruckman is correct the Premium Bose amp found in Hummers, Escalades, and Denali's only use two channel inputs, but the lower Bose amps will still fade front to rear like the ones in the Tahoes, Silverados, Yukons, Suburbans.
