Running power wire to 2 amps
sab0276
Copper - Posts: 61
Posted: May 01, 2006 at 4:28 PM / IP Logged
I have 2 amps that are going to be mounted next to each other. Can I run 1 thick power wire from the battery back to where the amps are and then split the wire from there? Or do I really have to run 2 seperate power wires directly from the battery back to each amp seperately?
The amps are a RF Punch 160.4 for the front and rear speakers, and a JBL GTQ400 for the subs.
Thanks.
-Scott
2002 GMC Yukon SLT non-Bose
Pioneer AVIC N3
xtremej
Gold - Posts: 1,440
Posted: May 01, 2006 at 4:36 PM / IP Logged
Run larger gauge wire back and use a distribution block to split the power to the amps. What are the rms outputs of your amps?
aznboi3644
Gold - Posts: 2,600
Posted: May 01, 2006 at 5:22 PM / IP Logged
Run atleast a 4 gauge power wire to a distribution block.
Also a ground distribution block will make things simpler.
sab0276
Copper - Posts: 61
Posted: May 01, 2006 at 9:11 PM / IP Logged
RMS 75Wx4 for the JBL and 20Wx4 for the RF.
-Scott
Pioneer AVIC N3
stevdart
Platinum - Posts: 5,816
Posted: May 01, 2006 at 10:28 PM / IP Logged
A distro block takes the place of splitting a large wire into two smaller wires and installing fuse holders in each of the smaller wires.  It's much simpler and way neater.  You can find a wide variety of fused distribution blocks.
danny boy
Member - Posts: 14
Posted: May 16, 2006 at 7:55 AM / IP Logged
can u run 1 wire from batt to amp (A) and earth amp (A) to desired location n run amp (B) of amp (A)
crzyvs
aznboi3644
Gold - Posts: 2,600
Posted: May 16, 2006 at 10:04 PM / IP Logged
huh?
aznboi3644
Gold - Posts: 2,600
huh?
aznboi3644
Gold - Posts: 2,600
Posted: May 16, 2006 at 10:05 PM / IP Logged
huh?
