Bass Blockers
ajrod27
Member - Posts: 20
Posted: May 02, 2006 at 12:27 AM / IP Logged
Ok, I installed some bass blockers in my explorer.  I put them on the small terminal of my jensen component speakers.  My question is, did I put them on the correct terminal?  I know that they have to go on the positive terminal, but the speakers didn't have the + and - marked.  Is there any problems that could occur because the bass blockers are on the negative terminal instead of the positive?
Thanks,
Arturo
stevdart
Platinum - Posts: 5,816
Posted: May 02, 2006 at 12:44 AM / IP Logged
The smaller terminal is negative.  Put the cap on the positive side.
At least, every diagram I've seen for this shows it on the + lead.  I'm still trying to figure out why.
geepherder
Platinum - Posts: 3,668
Posted: May 02, 2006 at 7:21 PM / IP Logged
Most manufacturers install the caps on the positive side, but electrically it doesn't matter.
ajrod27
Member - Posts: 20
Posted: May 02, 2006 at 10:04 PM / IP Logged
So, even though i put them on the wrong terminals they will still block out the unwanted frequencies?  Cuz when i put them on i could tell that they were either cutting out power or blocking low frequencies becuase the cones were not traveling as far as before.  I switched them to the positive terminal today and they sound cleaner, but the frequency response is the same as though they were on the negative.
Arturo
geepherder
Posted: May 03, 2006 at 6:28 AM / IP Logged
It makes no difference either way.
