receiver to Kawasaki mule
m3xciao6
Member - Posts: 18
Posted: May 02, 2006 at 5:10 PM / IP Logged
i need a second opinon on installin a cheap o wall mart reciver (200watts)to a kawasaki mule.  im not sure how many volts are commin off the battery it looks like this http://www.powersportsnetwork.com/accessoriesdetail/product=136474/levelcode=11407/catalog=1480/Kawasaki+Mule%99+Accessories/East+Penn+High+Capacity+Battery/accessories136474.htm
but im giong to need more than an reciver hook up kit, can sum1 give me feedback, is this possible?
haemphyst
Platinum - Posts: 5,059
Posted: May 03, 2006 at 8:40 AM / IP Logged
I can't say absolutely, but that looks like a 6 cell battery, or 12 volts. Check it with a VOM. 12 volts? You're good to go. + to the "Accessory" lead (red) and "Battery" (yellow) lead on the radio, and - to the "ground" (black). The CD and/or cassette will work perfectly fine, but the radio will give spotty reception, at best, without an antenna. You could look for a "bumper-mount", or possibly a "mag-mount" style antenna to fix that. Here's one option. Or, search through this stuff to see if there's something else you could use... I just went to yahoo, and searched for +bumper +mount +FM +antenna. By no means complete search, but it's a start for ya!
I don't know if there is an ignition switch on a Mule, or accessory position on any ignition switch that may be there, but you could always put the red lead there, so as to prevent having to remember to turn the radio off.
m3xciao6
Member - Posts: 18
Posted: May 03, 2006 at 8:16 PM / IP Logged
a few questions if u dont mind anwsering ,  the part about and antenna isnt important .  im having trubble understanding this
geepherder
Platinum - Posts: 3,668
Posted: May 04, 2006 at 12:56 PM / IP Logged
The yellow lead is the constant power supply for memory (clock, settings, etc.)- it needs a constant 12 volts (positive battery terminal).  The red wire is the switched lead and tells the radio to turn on when it receives 12 volts.  The black wire needs to be connected to ground (or the negative battery terminal).  All power wires need to be fused to prevent a fire.
m3xciao6
Member - Posts: 18
Posted: May 04, 2006 at 4:41 PM / IP Logged
great appreachate all the help , wut kind of wire is nessary ? ga? and when u say fused do u mean soderd together or with a fuse in it?
aznboi3644
Gold - Posts: 2,600
Posted: May 05, 2006 at 1:06 AM / IP Logged
He means to add an inline fuse with the power wires inbetween the battery and the deck. I would say 16-12 gauge wire. You can just use that gauge of speaker wire. Decks don't require huge wires for big current draws.
I made a custom box for my left over alpine HU and hooked it to a 13.8 volt power supply with 12 gauge speaker wire and it worked fine.
Sunday, February 15, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
