alpine type r wiring?
bruno71088
Copper - Posts: 161
Posted: May 07, 2006 at 8:25 PM / IP Logged
i currently own a jbl gto1201.1 which is 1100 watts rms at 2 ohm i was wondering if i got dual 2ohm alpine type r's how would i wire them to get a 2 ohm load and is this a good match?
boardinbum
Silver - Posts: 358
Posted: May 07, 2006 at 9:20 PM / IP Logged
How many Type R's?
If it's only two subs, wire them like this:
alpine type r wiring? -- posted image.
bruno71088
Copper - Posts: 161
Posted: May 07, 2006 at 9:32 PM / IP Logged
thanks that helps alot it will be 2 subs i forgot to say that. you guys think those subs are a good match for the amp there rated at 500rms each and 1500 max?
forbidden
Platinum - Posts: 5,354
Posted: May 07, 2006 at 9:58 PM / IP Logged
Sure they are a good sub. The question is what are you doing about the box. Good sound is all about the box. Read the stickies about boxes and box design for more info.
arrow12
Silver - Posts: 527
You should be fine, but set your gains correctly.  Do a search in this forum for "gain" if you don't know how.
That's my opinion. Take it, leave it, or correct me.
bruno71088
Copper - Posts: 161
Posted: May 07, 2006 at 10:04 PM / IP Logged
i have a slot ported box that is 1.75 cubic feet per chamber i built it myself to specs for some infinity's but when i was looking at the alpine i noticed they need 1.75 cubic feet for a ported encloser as well
forbidden
Posted: May 07, 2006 at 10:07 PM / IP Logged
Then all you might need to do is change the porting on it.
boardinbum
Silver - Posts: 358
Posted: May 07, 2006 at 11:05 PM / IP Logged
Do you know what the box is tuned to or how long the ports are?
