Eclipse 88120 dvc specs
bdl666
Silver - Posts: 330
Posted: May 12, 2006 at 5:03 PM / IP Logged
I have one of these brand new in the box, but the instructions manual is missing. I tried Eclipse's web site but they don't have anything older than 2004 there.
forbidden
Platinum - Posts: 5,354
Posted: May 12, 2006 at 6:16 PM / IP Logged
You want a 1.25 cu.ft.net sealed box for this sub. Build the boix closer to 1.4 cu.ft for gross internal volume. Double up the baffle board and do not use drywal screws to mount this sub as they will either break or rip out of the baffle (thus the double baffle). It will handle 500w rms. Coils are both 4 ohm.
bdl666
Silver - Posts: 330
Posted: May 12, 2006 at 7:56 PM / IP Logged
Thanks man!
Do you by any chance have the spec's sheet for this woofer.  I'll like to model it on WinIsd.
forbidden
Posted: May 13, 2006 at 2:45 AM / IP Logged
Not that I saw today when I had a quick look. From what I remember Eclipse did not give out all the needed specs on their sheet anyways. I can tell you though that after building over 50 of these boxes for that particular sub, it wails in it and sounds mighty fine Mr. Wolf.
Friday, January 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
