extending ports in bandpass
jayson358
Copper - Posts: 73
Posted: June 06, 2006 at 9:51 AM / IP Logged
my friend bought a bual 10" bandpass box the center chamber is sealed with the plexiglass front and the subs faces are in that part and the rear of the subs are in the ported chamber well the ports are only 4" wide and 4 1/2" long ace hardware sells pvc piping that will fit these ports exactly now my ? is would extending these ports give him a better bass response and it jus sound better overall and any suggestions helps i know about ported boxes and the dementions of the ports make a difference cause it changes the tuning fq of the box but ive never really messed with bandpass boxes cause theve never sound good but any suggestions for this box would be greatly appreciated thanx
93 diamante
pioneer deh-p3800mp
crossfire 40 band eq
alphasonik pma4075 mid amp
clif designs cd10.1Lx sub amp
powerbass xtreme 6 1/2 comp
"   " 6x9 rear
alpine 2 12" type r
ported 40hz tune
djfearny2
Silver - Posts: 810
Posted: June 06, 2006 at 10:35 AM / IP Logged
you can change the port length by adding the pvc. just go big than cut smaller than test etc. to see if you get a sound you want.
leave one sub normal and work on other sub so you can hear both before and after at the same time. Like i said start long and cut about 1/2 inch each time see if it changes the way it sounds.
Jon
Installer/Help Technician
---coral springs florida---
jayson358
Copper - Posts: 73
Posted: June 06, 2006 at 10:54 AM / IP Logged
thanx for the reply i appreciate it
93 diamante
pioneer deh-p3800mp
"   " 6x9 rear
alpine 2 12" type r
ported 40hz tune
Monday, April 6, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
