Will this amp work with these subs?
arkansasboy
Member - Posts: 35
Posted: June 09, 2006 at 1:01 AM / IP Logged
My friend has a brand spankin new 2400 watt Fosgate 2 Channel amp and he said he'd sell it to me for 300 dollars.........the thing is, will it work with my two 15" Soundstream Picasso subs. There Dual 4 voice coil subs. Will this set up work?
Dan Tha Man
spookiestylez
Silver - Posts: 531
Posted: June 09, 2006 at 1:14 AM / IP Logged
what is the model # on the amp? ....amp should be 2ohm stereo stable ...so wire each subs voice coils in parallel and to individual channels on the amp.
sS
rtfm
Blowntweeters
Silver - Posts: 650
Posted: June 09, 2006 at 1:18 AM / IP Logged
it will work fine. wire the subs in a series parallel combo to get a 4 ohm load. what type of enclosure do you have  ?
1974 ford pinto 4 15" punch Z power punch bd 1001 pioneer DEH-6700
arkansasboy
Member - Posts: 35
Posted: June 09, 2006 at 5:27 PM / IP Logged
I made a enclosure that has like 4 cubic foot of air space on the inside, so it is plenty big enough. Its just a square box design....no wall, just one big sealed chamber. I thought about wiring it as a parallel and then bridging it to the amp? Would that work?
Dan Tha Man
zhalverson
Copper - Posts: 180
Posted: June 09, 2006 at 7:08 PM / IP Logged
That's going to give you a load that amp is probably not going to like at all.  I would stick with the series parallel wiring setup.  Make sure the enclosure volume is what is recomended for those drivers as well.  Brace the enclsosure too.
arkansasboy
Member - Posts: 35
Posted: June 11, 2006 at 12:51 AM / IP Logged
Alright then, so I should probably go with a 4 ohm load then? Do you think that would sound better than a 1 ohm load on those 15's or should I look at getting a Class D amp?
Dan Tha Man
aznboi3644
Gold - Posts: 2,600
Posted: June 11, 2006 at 2:11 AM / IP Logged
1 ohm load on a normal 2 channel amp is going to do some damage. I mean you CAN wire it this way if you want to go ahead and buy a new amp.
No less than 4 ohms bridged or 2 ohms stereo.
Only a good class D amp will handle a 1 ohm load on some nice 15's
Ravendarat
Platinum - Posts: 2,806
Posted: June 11, 2006 at 1:40 PM / IP Logged
If the Rockford is a 2 channel amp than you MUST wire to 4 ohms in your case if you dont wanna cook it.  It should push your 15's just fine though. If he is your buddy, then ask him if you can hook it up first and try it out to see if you like it.
Wednesday, December 24, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
