Kicker 1200.1 problems
bluest4
Member - Posts: 37
Posted: June 16, 2006 at 10:25 AM / IP Logged
I have a kicker 1200.1 hooked up to a kicker L7 dual 4 ohm. And all the amp is doing is going into protection. Then the amp comes out of protection the sub hits and the amp goes back into protection and the cycle repeats itself over and over. I tryed hooking the speaker up at both 2 and 8 ohms and the same thing happened both times. What do u think this could be??
Steve
DYohn
Platinum - Posts: 10,741
Posted: June 16, 2006 at 12:17 PM / IP Logged
Gain is too high or your system voltage is dropping too low.  How did you set the gain?  What is the voltage at the amplifier power terminals?
bluest4
Member - Posts: 37
Posted: June 16, 2006 at 1:18 PM / IP Logged
13 volts at positive terminal, 13 volts at amp turn on, ground seems fine. The gain is all the way down. I think it is the amp because i swapped the power, ground and amp turn on that I was using on this amp to another amp and it worked fine.  ????
Steve
DYohn
Posted: June 16, 2006 at 1:25 PM / IP Logged
Yea, if you swapped amps and one worked where the other didn't, bad amp is a good bet.  :)  Did you power the same speakers with the test amp?  It is possible you have a bad speaker cable or a tinsel lead shorting to the speaker frame.
bluest4
Member - Posts: 37
Posted: June 16, 2006 at 1:28 PM / IP Logged
yah i powered the same speaker with the other amp.
supradude
Silver - Posts: 915
Posted: June 16, 2006 at 4:26 PM / IP Logged
Sound like the amp is definately bad.
'85 Toy
Friday, February 20, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
