music turns on and off!
jeepross
Posted: June 19, 2006 at 12:41 AM / IP Logged
i have a 2004 honda civic sedan and just recently put a headunit in it. for some reason the music will randomaly cut in and out....the head unit and subs both stay on and and the subs play whether the music is on or off......any ideas on what this could be or how to fix it? would running and amp to my interior speakers help?
aznboi3644
Gold - Posts: 2,600
Posted: June 19, 2006 at 12:52 AM / IP Logged
Are your interior speakers stock or aftermarket?
forbidden
Platinum - Posts: 5,354
Posted: June 19, 2006 at 12:55 AM / IP Logged
You have something dead shorting by the sounds of it. Time to pull apart the install and find out what is going on.
aznboi3644
Gold - Posts: 2,600
Posted: June 19, 2006 at 1:04 AM / IP Logged
Exactly my next point but forbidden got to it first.
jeepross
Posted: June 20, 2006 at 12:15 AM / IP Logged
i put all new infinity speakers in the car....so i just take out the head unit and re install it or what?     any specific things i should look at?
djfearny2
Silver - Posts: 810
Posted: June 20, 2006 at 7:52 AM / IP Logged
one or more of your speaker wires is more than likely shorting to ground. your looking for loose wire strands. bare wire. anything that could short out and cause the radio internal amp to shut down. check doors factory wires. basically check all the wires from the hu to the actual speakers shorting out.
Jon
Installer/Help Technician
---coral springs florida---
geepherder
Platinum - Posts: 3,668
Posted: June 21, 2006 at 9:06 AM / IP Logged
People on this forum have said some of the newer Infinity speakers are two ohm instead of four.  I'm not sure if this only deals with component speakers or not, but look into this.  It's possible this is your problem, too.
aznboi3644
Gold - Posts: 2,600
Posted: June 21, 2006 at 4:29 PM / IP Logged
Well yes...check the impepences of the speakers...if they are 2 ohm you better get an amp before you F up your HU.
