4 ohm dvc wiring?
realviper78
Member - Posts: 7
Posted: June 24, 2006 at 9:10 AM / IP Logged
i have read the wiring info on hte site and have a quesrtion as i am confused a little. i have 2 4 ohm dvc subs and the way the pic on the site shows makes sense hooking the speakers together and stuff to produce a 4 ohm load. but it goes to one positive and 1 negative and the subs box has two positives and 2 negatives for each speaker. so what do i do?
DYohn
Platinum - Posts: 10,741
Posted: June 24, 2006 at 9:13 AM / IP Logged
You connect the others together.  The electricity runs through one VC then the other then back to the amp (series connection.)  Like this:
4 ohm dvc wiring? -- posted image.
realviper78
Member - Posts: 7
Posted: June 24, 2006 at 9:17 AM / IP Logged
but the 2 speakers and the dual voice coils in that pic don't show me where the wires go from each sub to the 2 positive and negatives on hte left and right hand side of the box. i see how the dvc's are wired together but what about the two terminals on the left and right hand side of the box? lol maybe i just needa diff pic or something.
realviper78
Member - Posts: 7
Posted: June 24, 2006 at 9:23 AM / IP Logged
see i am not understanding something maybe this will make my point easier to get across. eahc sub has 4 wire connectors like in the diagram but them they have to go to 4 box wires. ie: left poitive and negative and same for the right. then fromm those 4 box wire be bridgged to the 2 amp wires. please help. thanks thats what i don't see on the disgram.
the12volt
Administrator - Posts: 3,959
Posted: June 24, 2006 at 9:45 AM / IP Logged
Connect each woofer as show below to each set of box terminals, then connect each set of box terminals in parallel.
4 ohm dvc wiring? -- posted image. the12volt • Support the12volt.com
realviper78
Member - Posts: 7
Posted: June 24, 2006 at 10:41 AM / IP Logged
ok great thanks for the help. once i hook each woofer up that way i would ru na pair or wires from the left box terminal to the right one wiht the positive and negative matching . then run another pair from the right box terminal to the amp?
eightem
Member - Posts: 7
Posted: June 24, 2006 at 4:09 PM / IP Logged
once they come out of the bot so u have 4 wires coming out of the box rite?
twist the 2 positives to gether and the 2 negitives together and connect it to the amp.
BOOM 1ohm
eightem
Member - Posts: 7
Posted: June 24, 2006 at 4:10 PM / IP Logged
dammit wrong button meant 4  ohm
realviper78
Member - Posts: 7
Posted: June 25, 2006 at 1:10 AM / IP Logged
beauti_ thank you for all your help guys. much appreciated. i'll let u know how it sounds once i get it all hooked up. of course once they come in the mail first lol. thanks again! 4 ohm dvc wiring? -- posted image.
realviper78
Member - Posts: 7
Posted: June 29, 2006 at 7:45 AM / IP Logged
if i connect a pair from the positive and negative left and right box terminals and then run another pair from the positive and negative of one side to the amp that would accomplishe the same with less wire would it not? it would be brisging it at the box and not hte amp?
