Line drivers and inverting a RF T-1 10?
importhunter
Copper - Posts: 76
Posted: August 02, 2006 at 6:51 AM / IP Logged
Anyone here use line drivers (RCA booster) for SPL comps?
I was told that their not needed by a local audio store.
However a couple of guys I go to comps with, use them.
Also what effect will inverting a T-1 10 have on SPL comps? Is it better normally installed with a decent sized port?
stevdart
Platinum - Posts: 5,816
Posted: August 02, 2006 at 7:48 PM / IP Logged
You should do some experimenting with a line driver if winning an SPL comp is your goal.  It's all about experimentation.  And inverting a subwoofer will not do anything for you.
jeffchilcott
Platinum - Posts: 2,483
Posted: August 02, 2006 at 9:27 PM / IP Logged
I have only noticed gains in using a Line driver when useing 2 or more amps.   For 2 or less, no diffrence at all.
For one of our 6 amp setups it did help
Inverting the sub has cause a few vehicles I know of to lose db vs gaining anthing besides having a big mag structure hanging out of the box
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
importhunter
Copper - Posts: 76
Posted: August 03, 2006 at 1:47 AM / IP Logged
Cool, well I will be running a 1200watt Rockford amp (401s I think) and 1 T-1 sub. I am not looking to set any recorsd but I would like to do better than a 134.8 with 4 P1s.
jeffchilcott
Posted: August 03, 2006 at 2:13 AM / IP Logged
what style comps are you running?   what orgnazation?    I could help you get much louder with the current setup you have, but need to know the Org to follow rules
2007 World Record
importhunter
Copper - Posts: 76
Posted: August 03, 2006 at 7:22 PM / IP Logged
Street 3 ( I think) in USAC
importhunter
Copper - Posts: 76
Posted: August 03, 2006 at 7:29 PM / IP Logged
I also run a outlaw class once a month.
We tried flipping down the visors, moving the seat foward, it helped maybe .2-3 DB.
Its in a 98 S-10 EXT cab if that helps.
My setup is as follows:
1 RFX-9220 deck
4 P1s wired @ 4 ohms
1200W rockford (401S)
2 i farad caps
big 3 upgrade with 4ga wire
optoma battery
My system runs at 14.75 volts @ 2000rpm.
importhunter
Copper - Posts: 76
Posted: August 07, 2006 at 11:21 AM / IP Logged
Hey Jeff what do you think?
jeffchilcott
Posted: August 07, 2006 at 1:50 PM / IP Logged
is the 134.8 the street beat run or outlaw>?
Is the box sealed or ported?
We did some testing with a rockford T-2 12 on a kicker kx1200.1 and it was in the low 140 range...about 144 if I remember right, and that was for outlaw...but it was A streetable setup so tuned very very low for comp use.
2007 World Record
importhunter
Copper - Posts: 76
Posted: August 07, 2006 at 6:50 PM / IP Logged
it was in outlaw. The box has 3 in ports.
Wednesday, March 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
