MTX Amps, good buy?
Flakman
Copper - Posts: 365
Posted: August 19, 2006 at 5:20 PM / IP Logged
I'm coming into a bit of cash and want to purchase amps for my two RF T112D4 subs. I was looking at two of the MTX TA5601 amps. I was also possibly looking at the LJ 1000/1 as well (I don't think I could spring for the Eclipse DA7232...it's a bit too far out of my range.). I was also looking into the Alpine MRD-M605s as well.
Edit --- Also considering two of the Eclipse XA4000s.
I guess I like the MTX and JLs because of the parametric adjustment capability.
The Flakman
I feel strange. I have deja vu and amnesia at the same time.
John | Manteca, CA
killer sonata
Silver - Posts: 718
Posted: August 19, 2006 at 7:00 PM / IP Logged
MTX have a high THD rating. You are better off with the eclipse amps. MTX amps are good for subs, not so much for door speakers.
kfr01
Gold - Posts: 2,121
Posted: August 19, 2006 at 7:43 PM / IP Logged
If the MTX will fit better into your budget, go with them.
killer - don't place too much stock in THD numbers, especially in car audio.
New Project: 2003 Pathfinder
killer sonata
Silver - Posts: 718
Posted: August 19, 2006 at 8:19 PM / IP Logged
all i can say is that i went from a MTX 564 with a THD of 1.2% to an eclipse XA4000 which has less than .05% THD and the improvement was phenominal.
kfr01
Gold - Posts: 2,121
Posted: August 19, 2006 at 8:59 PM / IP Logged
Maybe.  But it wasn't due to the THD numbers.
First, even in very controlled home environments you'd have to have great (read:  extraordinary) ears to pick out 1.2% THD from 0.05% THD.
Second, you likely don't have great (read: extraordinary) ears.
Third, your speakers and the "room" that is your car cabin exhibit and cause non-linearities and distortions orders of magnitude greater than any you'll find on even crap electronics.  The assertion that you can attribute an extra 1% to a different amplifier is quite dubious.
Fourth, once the motor starts running, THD numbers under, hell, 5%, likely fly out the window and are rendered null in 99/100 vehicles.
Don't get me wrong, I like nice stuff.  And you're right, Eclipse generally makes nicer stuff than MTX.  However, I don't want to see any new members be misled into buying an amplifier for a THD number.  Which, in my opinion, is one of the most useless numbers in car audio electronics.
fresh155
Member - Posts: 12
Posted: August 19, 2006 at 9:59 PM / IP Logged
Personally i have been through several amps for my subs from jbl to profile and pioneer and for me the one i like the most which i currently have is the alpine i have the older model of the version you stated above and it has been problem free and i abuse it everyday. it is a great amp especially at 2ohm. just make sure whatever amp you pick give it the proper gauge for power wire and ground or you will lose power. also i found my amp had better power and response once i installed a capacitor for it. i usually use 4 gauge wire for power and ground hope this helps
Platinum - Posts: 12,488
Posted: August 20, 2006 at 9:07 AM / IP Logged
My money is on the MRX stuff because they have the built in fans into all the amplifiers which is a huge deal if venting is an issue in your installation. I have heard and seen many amps in my neck of the woods shut down due to thermal protection kicking in because of lack of air space.
Flakman
Copper - Posts: 365
Posted: August 20, 2006 at 4:48 PM / IP Logged
Hopefully you mean the MTX stuff [:)]
That's where I'm leaning towards. Next week I'll pull the trigger on the purchase.
Thanks everyone.
The Flakman
John | Manteca, CA
auex
Platinum - Posts: 5,041
Posted: August 21, 2006 at 4:48 AM / IP Logged
I don't really like the lower end MTX stuff, but never had a problem with them. Subs were good.
But like kfr01 said, do what is in your budget unless it is a really low end piece of equipment then save your money for something better. You will be better in the long run.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
