Alpine IVA-W200 DVD Playback Issue
kylewest1320
Member - Posts: 10
Posted: August 24, 2006 at 10:57 AM / IP Logged
I have the Alpine IVA-W200 and PXA-H701 Combo, and for some reason when I play a DVD I get absolutely no sound out of my component tweeters. The thing is, with CD's, or Sirius, sounds come out fine (actually awesome) from all my speakers, its just with DVD's. Any insight on this?
Thank you
tcss
Silver - Posts: 1,623
Posted: August 24, 2006 at 11:43 AM / IP Logged
Try going from "output 1" to "output 2" on the PXA-H701.
There is no such thing as free installation!
kylewest1320
Member - Posts: 10
Posted: August 24, 2006 at 11:52 AM / IP Logged
On the RCA's output to the amps?
tcss
Posted: August 24, 2006 at 11:54 AM / IP Logged
Yes
kylewest1320
Member - Posts: 10
Posted: August 24, 2006 at 12:06 PM / IP Logged
Ok, will try that in a few, thanks for the tip.
tcss
Posted: August 24, 2006 at 12:16 PM / IP Logged
Let me know if it works, we had the same issue in our display board.
kylewest1320
Member - Posts: 10
Posted: August 24, 2006 at 1:30 PM / IP Logged
Well I figured out that I had the rear inputs to the amps in the front ouput off the processor, so now I at least get sound out of my tweeters, but its very low. I think I just need some time to fully tune them.
I have another question for you, not sure if you deal with Zapco or not, but I have 2 of their DC Reference Series amps, which are the digital ones, they have built in x-overs, eq's, etc. Do you think I should run the x-over's and eq off the Alpine or use the Zapco?
Thanks for all your input
tcss
Posted: August 24, 2006 at 1:39 PM / IP Logged
Two schools of thought here. My sales manager has a D-310 with the H-701 and he's a real tweek. He uses the X-overs in the 701 because he will adjust the X-over points for differant sources. Like I said, a REAL tweek. Myself, I use the X-overs on my JL amps because I think they sound better then the ones in the 701. See if you can hear a differance, if not use the ones in the 701.
kylewest1320
Member - Posts: 10
Posted: August 24, 2006 at 1:46 PM / IP Logged
Thanks man, really appreciate it.....
