Mission accomplished!
haemphyst
Platinum - Posts: 5,059
Posted: September 29, 2006 at 4:27 PM / IP Logged
Sitting in Bob's shop typing this... Panels are done, man! Pictures to follow, right Bob?
Personally, I think they look awesome! Acoustically, they are optimally placed, and I think they are going to sound awesome!
Flakman
Copper - Posts: 365
Posted: September 29, 2006 at 4:53 PM / IP Logged
Haem...that's not fair posting without the pics Mission accomplished! -- posted image.Mission accomplished! -- posted image.
The Flakman
I feel strange. I have deja vu and amnesia at the same time.
John | Manteca, CA
forbidden
Platinum - Posts: 5,354
Posted: September 29, 2006 at 4:54 PM / IP Logged
So, how did we take on this task.....any moving of the window motors involved or did you opt for plan B?
tcss
Silver - Posts: 1,623
Posted: September 29, 2006 at 5:38 PM / IP Logged
Actually we got off easy. Used Ham's door panels as a mold, covered them with tin foil and layed in the glass. took them out and filled with expanding foam. After the foam hardened cut it to shape and made MDF rings for the drivers. Layed another layer of glass over everything mounted drivers and covered with grill cloth. Done.
There is no such thing as free installation!
haemphyst
Posted: September 30, 2006 at 8:30 AM / IP Logged
I wasn't even there to see the process, but the guys said they took snaps as they were being built... I've got a/my company picnic to emcee today (lucky me - I was conscribed to it...) so I won't even be able to work on wiring it in today. Mission accomplished! -- posted image.
TOMORROW, though... I may (although WILL is I think, more accurate...) have to do some serious cutting to get the Adires jammed into the doors, but they're going in, dammit! I figured about 450 watts per door, tri-amped, will be the final power tally. I have hopes for this system like nobody on this board can even imagine. Mission accomplished! -- posted image. This is 5 years of acquiring of components, and more time than that designing and installing, and putting in "good enough for now" systems, people! <Dave scratches his head and thinks, "Has it really been that long? Jeez, I gotta get more sunlight.">
Plan B... Flushed into the surface. Sure the surface is three inches further INTO the passenger compartment than it was before... Mission accomplished! -- posted image.
And finally... 66 people have looked, but is NOBODY interested in a babied, like new Eclipse SW9122? Mission accomplished! -- posted image.
Platinum - Posts: 12,488
Posted: September 30, 2006 at 8:39 AM / IP Logged
Bold.... very bold. Hope your work pays off and wait till I get the time to work on my project vehicle. It will be a couple year project in the works, but when I'm done " I  have hopes for this system like nobody on this board can even imagine. Mission accomplished! -- posted image. " Mission accomplished! -- posted image. Let's see some pics Dude !!
haemphyst
Posted: September 30, 2006 at 8:54 AM / IP Logged
OK... ...like very few people on this board can even imagine.
haemphyst
Posted: September 30, 2006 at 10:13 AM / IP Logged
There will be rear, but only bass. In the front doors, the Adire Extremis 6.8 will run from maybe 80 to 100 Hz and up to 350Hz with a dedicated 200wpc. The low frequency cross-in point of this driver will be determined in the tuning stage.
The mids will be handled by a custom (Harman modified) Vifa mid, running from 350Hz to 4kHz, with a dedicated (approximate) 120wpc.
The higs are handled by the newly acquired JL silk-dome tweeters, 4K and up, with a dedicated 85wpc.
Sub bass (and I do mean SUB bass) will be two TCSounds TC1000 10" subwoofers, in one cubic foot each, powered by the Eclipse DA7232. I am planning a relay system with a control switch in the dash to switch between 8 ohm load, producing around 450 WRMS per woofer, and 2 ohm load, providing around 950 WRMS per woofer, and providing an additional 6dB of sensitivity, too. These will be subsonic high-passed at around 20 to 22Hz, and low-passed at 50Hz.
All wires are Monster, with 14g for the tweeters and mids and 12g for the Adires.
Processing is handled by the VERY capable (and quite expensive, I might add) Alto UCSPro Digital Control System. Two of those in the system - one for the rears and one for the doors. Amplification and head unit, are of course, Eclipse.
The rear deck will have Tang-Band 7 inch subwoofers, running from the sub crossover point of 50Hz up to the Adires in the door.
All crossover points will be as steep as possible, minimum 36dB. The rear drivers will all be 48dB slopes.
tcss
Posted: September 30, 2006 at 12:39 PM / IP Logged
I hope to post the pictures today.
DYohn
Platinum - Posts: 10,741
Posted: September 30, 2006 at 3:04 PM / IP Logged
Sounds like a good foundation, and like a real potential female dog to get the crossovers and levels all tweaked.  Time for a serious RTA and probably hours of EQ work, my friend.  Have a great time doing it, I know I would! Mission accomplished! -- posted image.
Page of 5
